I am trying to calculate RPS and display to an LCD but am getting odd results.
RPS is showing up as 6.00 instantly when its not rotating. PulseCounter is displaying 993 or 994. Neither update when spinning the encoder. The "updateEncoder" block functions properly and appears to show 150 Pulses on a 360 degree rotation.
void simulatedEncoder(){
if (micros() - prevMicros >= pulseInterval){ //simulated encoder spinning
prevMicros += pulseInterval; // don't lose random microseconds
pulseCounter ++; //increment every 1000 micros
The lcd code may also affect the timing, the technique above will automatically catch up if ever delayed more than pulseInterval.
Also change:
void displayCount(){
if (millis() - prevMillis >= updateMillis){ //update display & calc every second
prevMillis = millis();
to
prevMillis += updateMillis;
for same reason.
This should get the 993/994's to be 1000+/-1
Your ISR can be improved:
void updateEncoder(){
int MSB = digitalRead(encoderPin1); //MSB = most significant bit
int LSB = digitalRead(encoderPin2); //LSB = least significant bit
int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
lastEncoded = encoded; //store this value for next time
// pulseCounter ++; // increment when receives single pulse
to
byte encoded = (digitalRead(encoderPin1) << 1) | digitalRead(encoderPin2);
encoded = encoded ^ (encoded >> 1) ; // convert Gray code to phase (0..3)
byte diff = encoded - lastEncoded ; //numerical difference between current and last phase
diff &= 3 ; // ensure phase in range 0..3, really a number of quadrants to turn.
lastEncoded = encoded ;
if (diff == 3) // check sign of 2 bit 2's complement phase difference value
encoderValue ++ ;
else if (diff == 1)
encoderValue -- ;
Note that reading encoderValue in the main part of the program requires a critical section
as its more than one byte:
noInterrupts();
long my_value = encoderValue ; // dont allow ISR to run inbetween reads of the 4 bytes of the var.
interrupts() ;
Oh wow, this is great. @Capt-Nemo, I am calculating RPS by polling the # of pulses every 1 sec and dividing the two. I suppose there is a margin of error but not sure how much it is or if it should be considered. I am hoping for accuracy to the 100th second (Ex 9.98 RPS).
@MarkT, Thank you. The timer change make sense and wouldn't have thought of that. The "fake timer" seems to function properly, though my attempt to switch to the encoder breaks as the total pulse count isn't being added up.
I've read the ref material but am not entirely following the "diff&= 3" explanation. Probably because I don't understand the patterns the encoder are sending. I found this article helpful. I gather this section of code is looking for 2 HIGH channels and if so incrementing the encoder to 2. Are there bounce issues? Or is it pretty much this type of a pattern?
When both are HIGH, should I not be adding "pulseCounter ++;"? Would this be here (see below) or at the end of the updateEncoder function IF both are HIGH?
if (diff == 3){ // check sign of 2 bit 2's complement phase difference value
encoderValue ++ ;
pulseCounter ++ ;
The note re noInterrupts makes sense, though didn't have luck with where to place it. I believe it would be here:
noInterrupts();
pulseCounter = encoderValue ; // dont allow ISR to run inbetween reads of the 4 bytes of the var.
interrupts() ;
RPS = pulseCounter/encFullCycle;
I believe everything is working well after adding "pulseCounter ++" at the end of updateEncoder and "pulseCounter = 0" at the end of the displayCount loop.
Changing encFullCycle to a float and value of 150.0 also allows decimal values for RPS.
Here's the code for others should they need it:
int encoderPin1 = 2;
int encoderPin2 = 3;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
//fake Timer int pulseInterval = 1000; //simulating encoder ++ every 1000 micros
//fake timer unsigned long prevMicros = 0;
int pulseCounter = 0; //add up pulses
float encFullCycle = 150.0; //# of encoder pulses per full rev
float RPS; //= pulseCounter/pulsesPerRev; figured out later
int motorSteps = 400; //per rev
float microSteps = 4; //1/2 micro steps = 2x pulses req'd
int pulsesPerRev = motorSteps * microSteps; // likely 800 pulses per rev
unsigned long updateMillis = 1000; //Calculate RPS every 1 sec
unsigned long prevMillis = 0;
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 7, d5 = 6, d6 = 5, d7 = 4;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Serial.begin (9600);
lcd.begin(16, 2);
pinMode(encoderPin1, INPUT_PULLUP);
pinMode(encoderPin2, INPUT_PULLUP);
digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
attachInterrupt(0, updateEncoder, CHANGE);
attachInterrupt(1, updateEncoder, CHANGE);
void loop(){
// simulatedEncoder();
displayCount();
encoderValue ++ ;
else if (diff == 1) {
encoderValue -- ;
pulseCounter ++; //***NEW
lcd.setCursor(0, 0);
lcd.print("RPS: "); lcd.print(RPS, 3);
lcd.setCursor(0, 1);
lcd.print("Pulses: "); lcd.print(pulseCounter);
pulseCounter = 0; // reset counter ***NEW
//void simulatedEncoder(){
// if (micros() - prevMicros >= pulseInterval){ //simulated encoder spinning
// prevMicros += pulseInterval; // don't lose random microseconds
// pulseCounter ++; //increment every 1000 micros
