rs 232 / TTL coverter not working
i have an rs232 / ttl converter and i cannot get it to output the rs232 data to the arduino
the rs232 data is being send from a tracking device
i can connect the rs232 port to the usb / serial adaptor and i am able to output the data being transmitted to screen. I am using a third party serial monitor software to read the rsa232 data So this proves the tracking device is outputting the data correctly
when i unplug the d9 connector from the serial / usb adaptor and connect it to the d9 of the rs232 / ttl connector the data does not appear on the arduino monitor
below is my sketch i am trying
any advise would be appreciated i have been working on this for days and i cannot get it working
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
  • RX is digital pin 10 (connect to TX of other device)
  • TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo and Micro support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
mySerial.println("Hello, world?");
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
You may need to swap pins 2 & 3 between the DB9 on the RS232/TTL converter and the RS232 cable.
Unfortunately with SoftwareSerial it is not possible to do a loopback test on the RS232/TTL converter to verify if those connections are correct, SoftwareSerial has problems with receiving its own send data.
