rs 485 communication with dc energy meter 1000v and ardunio registers output
I am doing dc meter 1000v with ardunio and rs 485.The problem is that when i am sending register value from ardunio i am not getting the output as i want, the output is in hexa decimal, and i cant figure out where is the voltage and current???? plus when i am changing voltage input i am not getting change output so far the code is...
#include <Stdio.h>
#include <SoftwareSerial.h>
#define RX 4
#define TX 5
SoftwareSerial softSerial(RX, TX);
#define dirPin 16
char charArray[6];
uint8_t HeadingData[] = {0x01, 0x04, 0x00, 0x00, 0x00, 0x02, 0x71, 0xCB};
softSerial.begin(9600);
Serial.println("\n\nStart\n");
pinMode(dirPin, OUTPUT);
digitalWrite(dirPin, HIGH); //Trans En
sendMSG(HeadingData, sizeof(HeadingData));
digitalWrite(dirPin, LOW); // Rec En
recieveMSG();
void recieveMSG()
int charIndex = 0;
delay(100);
while (softSerial.available())
int recieved = softSerial.read();
// Serial.print("recieved byte in DEC = ");
// Serial.println(recieved);
Serial.print("recieved byte in HEX = ");
Serial.println(recieved, HEX);
// delay(50000);
// charArray[charIndex] = recieved; // store everything that was read in charArray byte-by-byte
// charIndex++;
// Serial.println(charArray[0], HEX);
// Serial.println(charArray[1], HEX);
// Serial.println(charArray[2], HEX);
// Serial.println(charArray[3], HEX);
// Serial.println(charArray[4], HEX);
// Serial.println(charArray[5], HEX);
// Serial.println("message recieved\n\n");
void sendMSG(uint8_t Message[], int len)
for (int i = 0; i < len; i++)
softSerial.write(Message*);*
  • delay(10);*
    _ Serial.print(Message*, HEX);_
    _
    Serial.print(" ");_
    _
    }_
    _
    Serial.println("\n\n");_
    _
    }*_
    please tell where i am wrong whats needs to be change??
Hi, welcome on the forum. Please have a look at How to use this forum and try to edit you post accordingly :wink:
Next, "dc meter 1000v" doesn't tell jack about the device which is pretty important if you want to know what it outputs...
HI
i am integrating dc energy meter with rs 485 and arduino,but i am having problem with the registers.As the supplier of the meter provided me fake instruction book...
Please if anybody has used this meter provide me its registers of current and voltage from the instruction book
Thankyou..
@Mariajaved, do not cross-post. Threads merged.
