it doesn't receive the data. when i only use one of them, it updates each 5 secondes or so but when i use another one, it takes up to 2-3 minutes between each updates. it sometimes doesn't receive it at all.
heres the full code
Master code :
#include <DallasTemperature.h>
#include <OneWire.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#define ONE_WIRE_BUS 4
OneWire oneWire (ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress RG1 = { 0x28, 0x5D, 0x72, 0x95, 0xF0, 0x01, 0x3C, 0xA0 };
DeviceAddress RG2 = { 0x28, 0x85, 0xF7, 0x95, 0xF0, 0x01, 0x3C, 0xDC };
DeviceAddress RG3 = { 0x28, 0xD0, 0x1D, 0x95, 0xF0, 0x01, 0x3C, 0x7E };
DeviceAddress RD1 = { 0x28, 0xB3, 0xE7, 0x95, 0xF0, 0x01, 0x3C, 0xFF };
DeviceAddress RD2 = { 0x28, 0x02, 0x4A, 0x95, 0xF0, 0x01, 0x3C, 0x10 };
DeviceAddress RD3 = { 0x28, 0xC1, 0x17, 0x95, 0xF0, 0x01, 0x3C, 0xAF };
int flowpin = 3;
unsigned long currentmillis;
unsigned long lastMillisScroll;
unsigned long currentMillis1;
unsigned long currentMillis2;
unsigned long currentMillis3;
unsigned long currentMillis4;
unsigned long lastMillis1;
unsigned long lastMillis2;
unsigned long lastMillis3;
unsigned long lastMillis4;
double flowRate;
volatile int count;
int menu = 1;
boolean th1 = 0; //Chambre mik
float tath1 = 0;//
float tpth1 = 0;//
boolean th2 = 0; //Chambre bibi
float tath2 = 0;//
float tpth2 = 0;//
boolean th3 = 0; //Chambre will
float tath3 = 0;//
float tpth3 = 0;//
boolean th4 = 0; //Chambre Jade
float tath4 = 0;//
float tpth4 = 0;//
boolean th5 = 0; //sal de bain du sous-sol
float tath5 = 0;//
float tpth5 = 0;//
boolean th6 = 0; //Entrée + sal de lavage
float tath6 = 0;//
float tpth6 = 0;//
boolean th7 = 0; //Bureau de cyndie
float tath7 = 0;//
float tpth7 = 0;//
boolean th8 = 0; //Chambre des maitres
float tath8 = 0;//
float tpth8 = 0;//
boolean th9 = 0; //Walking des maitres
float tath9 = 0;//
float tpth9 = 0;//
boolean th10 = 0; //sal de bain des maitres
float tath10 = 0;//
float tpth10 = 0;//
boolean th11 = 0; //Salle de bain
float tath11 = 0;//
float tpth11 = 0;//
boolean th12 = 0; //2eme etage
float tath12 = 0;//
float tpth12 = 0;//
int p1 = 46; //spa
int p2 = 48; //eaux chaudes
int p3 = 50; //sous-sol
int p4 = 52; //2eme etage
int p5 = 28; //rez-de-chausser
int p6 = 29; //garage
int p7 = 30; //vide
int v1 = 35; //Chambres des maitres
int v2 = 37; //Walking des maitres
int v3 = 39; //Salle de bain des maitres
int v4 = 41; //Entrée
int v5 = 43; //Salle d'eau
int v6 = 45; //Bureau de Cyndie
int v7 = 47; //Chambre de Bibi
int v8 = 49; //Chambre de Will
int v9 = 51; //Salle de bain sous-sol + hall
int v10 = 53; //Chambre de Mik
int v11 = 34; //Chambre de Jade
int v12 = 36; //vide
int v13 = 38; //vide
int v14 = 40; //vide
int v15 = 42; //vide
int v16 = 44; //vide
int Enable = 2;
Serial1.begin(9600);
pinMode (p1, OUTPUT);
pinMode (p2, OUTPUT);
pinMode (p3, OUTPUT);
pinMode (p4, OUTPUT);
pinMode (p5, OUTPUT);
pinMode (p6, OUTPUT);
pinMode (p7, OUTPUT);
pinMode (v1, OUTPUT);
pinMode (v2, OUTPUT);
pinMode (v3, OUTPUT);
pinMode (v4, OUTPUT);
pinMode (v5, OUTPUT);
pinMode (v6, OUTPUT);
pinMode (v7, OUTPUT);
pinMode (v8, OUTPUT);
pinMode (v9, OUTPUT);
pinMode (v10, OUTPUT);
pinMode (v11, OUTPUT);
pinMode (v12, OUTPUT);
pinMode (v13, OUTPUT);
pinMode (v14, OUTPUT);
pinMode (v15, OUTPUT);
pinMode (v16, OUTPUT);
digitalWrite(v1, HIGH);
digitalWrite(v2, HIGH);
digitalWrite(v3, HIGH);
digitalWrite(v4, HIGH);
digitalWrite(v5, HIGH);
digitalWrite(v6, HIGH);
digitalWrite(v7, HIGH);
digitalWrite(v8, HIGH);
digitalWrite(v9, HIGH);
digitalWrite(v10, HIGH);
digitalWrite(v11, HIGH);
digitalWrite(v12, HIGH);
digitalWrite(v13, HIGH);
digitalWrite(v14, HIGH);
digitalWrite(v15, HIGH);
digitalWrite(v16, HIGH);
digitalWrite(p1, HIGH);
digitalWrite(p2, HIGH);
digitalWrite(p3, HIGH);
digitalWrite(p4, HIGH);
digitalWrite(p5, HIGH);
digitalWrite(p6, HIGH);
digitalWrite(p7, HIGH);
pinMode (Enable, OUTPUT);
digitalWrite(Enable, HIGH);
pinMode(flowpin, INPUT);
attachInterrupt(1, Flow, RISING);
sensors.begin();
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Master Thermostats");
lcd.setCursor(0, 3);
lcd.print("Version 1.0");
delay(2000);
lcd.clear();
sensors.requestTemperatures();
currentmillis = millis();
//------------------menu-------------------//
lcd.clear();
switch (menu) {
case 1:
lcd.clear();
lcd.print("Chambre mik");
lcd.setCursor(4, 1);
lcd.print("temperature:");
lcd.setCursor(0, 2);
lcd.print("A:");
lcd.setCursor(2, 2);
lcd.print(tath1);
lcd.setCursor(12, 2);
lcd.print("P:");
lcd.setCursor(14, 2);
lcd.print(tpth1);
if (th1 == 1) {
lcd.setCursor(9, 3);
lcd.print("On ");
lcd.print("Off");
case 2:
lcd.clear();
lcd.print("Hall d'Entree");
lcd.print("A:");
lcd.print(tath6);
lcd.print("P:");
lcd.print(tpth6);
if (th6 == 1) {
lcd.print("On ");
lcd.print("Off");
case 3:
lcd.clear();
lcd.print("reverse1");
lcd.setCursor(12, 0);
lcd.print("reserve2");
lcd.setCursor(12, 1);
lcd.print(sensors.getTempC(RG1));
lcd.print(sensors.getTempC(RG2));
lcd.setCursor(12, 3);
lcd.print(sensors.getTempC(RG3));
lcd.setCursor(0, 1);
lcd.print(sensors.getTempC(RD1));
lcd.print(sensors.getTempC(RD2));
lcd.print(sensors.getTempC(RD3));
//------------------------Logique-----------------------//
if (th6 == 1 && sensors.getTempC(RG2) >= 60 && sensors.getTempC(RD2) >= 60){
digitalWrite(p3, LOW);
digitalWrite(p4, LOW);
digitalWrite(p5, LOW);
if (sensors.getTempC(RG3) >= 72 && sensors.getTempC(RD3) >= 72) {
digitalWrite(p6, LOW);
if (sensors.getTempC(RG3) <= 70 && sensors.getTempC(RD3) <= 70) {
//Entrée
Serial1.print("I");
Serial1.print("16"); // slave id
Serial1.print("L");
Serial1.print("F");
Serial1.flush();
digitalWrite(Enable, LOW);
delay(15);
if (Serial1.find("i")) {
delay(10);
if (Serial1.read() == '6') {
th6 = Serial1.parseInt();
if (Serial1.read() == 'a') {
tath6 = Serial1.parseFloat();
if (Serial1.read() == 'p') {
tpth6 = Serial1.parseFloat();
if (Serial1.read() == 'f') {
delay(100);
if (flowRate >= 1) {
digitalWrite(p2, LOW);
count = 0;
interrupts();
noInterrupts();
flowRate = (count * 2.25);
flowRate = flowRate * 60;
flowRate = flowRate / 1000;
if (currentmillis - lastMillisScroll >= 2000) {
lastMillisScroll = currentmillis;
menu = menu + 1;
if (menu == 4) {
menu = 1;
//----------------interrupt---------------//
void Flow() {
count++;
Slave code :
int menu = 0;
int parametres = 0;
unsigned long LastTimeButtonPressed;
unsigned long CurrentTime;
const int Enable = 2;
const int Sl1 = 16;
float dAmbiant = 1;
float dPlancher = 2;
float minAmbiant = 15;
float maxAmbiant = 28;
float minPlancher = 15.5;
float maxPlancher = 28;
int LastButtonPressed = 0;
int th1 = 1;
float setTempAmbiant = 19.5;
float setTempPlancher = 25.5;
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET 4
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define ONE_WIRE_BUS 3 //Pin sur laquelle est connecter les capteur de temperature
DeviceAddress S1 = { 0x28, 0x4C, 0x0F, 0x95, 0xF0, 0x01, 0x3C, 0x4D }; //AMBIANT
DeviceAddress S2 = { 0x28, 0xEC, 0x64, 0x95, 0xF0, 0x01, 0x3C, 0x70 }; //PLANCHER
float tath = 0;
float tpth = 0;
const uint8_t Maison1 [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x06, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x30, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x20, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x06, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x08, 0x00,
0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x05, 0x80,
0x00, 0x00, 0x04, 0x40, 0x00, 0x00, 0x04, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x04, 0x00,
0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x04, 0x00,
0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x04, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xc0, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x30, 0x18, 0x60, 0x00,
0x00, 0x00, 0x00, 0x10, 0x08, 0x20, 0x10, 0x00, 0x00, 0x00, 0x00, 0x20, 0x04, 0x40, 0x08, 0x00,
0x00, 0x00, 0x00, 0x21, 0x84, 0x43, 0x08, 0x00, 0x00, 0x00, 0x00, 0x22, 0x44, 0x44, 0x88, 0x00,
0x00, 0x00, 0x00, 0x22, 0x44, 0x44, 0x88, 0x00, 0x00, 0x00, 0x00, 0x22, 0x44, 0x44, 0x88, 0x00,
0x00, 0x00, 0x00, 0x22, 0x44, 0x44, 0x88, 0x00, 0x00, 0x00, 0x00, 0x22, 0x43, 0x84, 0x88, 0x00,
0x00, 0x00, 0x00, 0x22, 0x40, 0x04, 0x88, 0x00, 0x00, 0x00, 0x00, 0x22, 0x20, 0x08, 0x88, 0x00,
0x00, 0x00, 0x00, 0x22, 0x18, 0x30, 0x88, 0x00, 0x00, 0x00, 0x00, 0x14, 0x07, 0xc0, 0x50, 0x00,
0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const uint8_t Flame2 [] PROGMEM = {
0x00, 0x00, 0x20, 0x40, 0x40, 0x40, 0x20, 0x10, 0x10, 0x10, 0x20, 0x00, 0x00
pinMode(Enable, OUTPUT);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
sensors.begin();
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial1.println(F("SSD1306 a manquer sa shot"));
for (;;);
display.display();
display.clearDisplay();
if (digitalRead(6) == LOW) {
LastButtonPressed = 4;
LastTimeButtonPressed = CurrentTime;
CurrentTime = millis();
if ((digitalRead(6) == LOW && menu == 1) && (parametres == 0)) {
menu = -1;
if ((digitalRead(6) == LOW && menu != 2) && (parametres == 0)) {
menu++;
if (CurrentTime - LastTimeButtonPressed > 10000) {
menu = 0;
parametres = 0;
if ((CurrentTime - LastTimeButtonPressed > 3000 && menu == -1) && (parametres <= 7)) {
if ((digitalRead(4) == LOW && menu == 1) && (setTempAmbiant != minAmbiant)) {
setTempAmbiant = setTempAmbiant - 0.5;
if ((digitalRead(5) == LOW && menu == 1) && (setTempAmbiant != maxAmbiant)) {
setTempAmbiant = setTempAmbiant + 0.5;
if (digitalRead(6) == LOW && menu == 0) {
menu = 1;
if ((sensors.getTempC(S1)) <= setTempAmbiant - dAmbiant && (sensors.getTempC(S2)) <= setTempPlancher - dPlancher) {
th1 = 1;
if ((sensors.getTempC(S1)) >= setTempAmbiant || (sensors.getTempC(S2)) >= setTempPlancher) {
th1 = 0;
if ((digitalRead(4) == LOW && digitalRead(5) == LOW) && (menu >= 0)) {
parametres = 1;
menu = -1;
if ((digitalRead(5) == LOW && parametres < 7) && (LastButtonPressed != 4 && menu == -1)) {
parametres++;
LastButtonPressed = 3;
if ((digitalRead(4) == LOW && parametres >= 1) && (LastButtonPressed != 4 && menu == -1)) {
parametres--;
LastButtonPressed = 2;
if ((parametres == 1 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
dAmbiant = dAmbiant + 0.5;
if ((parametres == 1 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
dAmbiant = dAmbiant - 0.5;
if ((parametres == 2 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
dPlancher = dPlancher + 0.5;
if ((parametres == 2 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
dPlancher = dPlancher - 0.5;
if ((parametres == 3 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
minAmbiant = minAmbiant + 0.5;
if ((parametres == 3 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
minAmbiant = minAmbiant - 0.5;
if ((parametres == 4 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
maxAmbiant = maxAmbiant + 0.5;
if ((parametres == 4 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
maxAmbiant = maxAmbiant - 0.5;
if ((parametres == 5 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
minPlancher = minPlancher + 0.5;
if ((parametres == 5 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
minPlancher = minPlancher - 0.5;
if ((parametres == 6 && LastButtonPressed == 4) && (digitalRead(5) == LOW)) {
maxPlancher = maxPlancher + 0.5;
if ((parametres == 6 && LastButtonPressed == 4) && (digitalRead(4) == LOW)) {
maxPlancher = maxPlancher - 0.5;
if ((parametres == 7 && LastButtonPressed == 4) && (digitalRead(5) == LOW && setTempPlancher != maxPlancher)) {
setTempPlancher = setTempPlancher + 0.5;
if ((parametres == 7 && LastButtonPressed == 4) && (digitalRead(4) == LOW && setTempPlancher != minPlancher)) {
setTempPlancher = setTempPlancher - 0.5;
if (parametres >= 5) {
display.setCursor(10, 35);
display.print("Version 1.0");
switch (menu) {
case 0:
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.setTextSize(2);
display.print(sensors.getTempC(S1));
display.print("C");
display.print((char)247);
display.setCursor(0, 20);
display.setTextSize(1);
display.print(setTempAmbiant);
display.print("C");
if (th1 == 1) {
display.print("...");
display.drawLine(0, 32, 128, 32, SSD1306_WHITE);
display.drawLine(90, 32, 116, 32, BLACK);
display.drawBitmap(64, 1, Maison1, 64, 64, WHITE);
display.setCursor(0, 48);
display.print(sensors.getTempC(S2));
display.print("C");
display.setCursor(0, 38);
display.print(setTempPlancher);
display.print("C");
display.display();
case 1:
display.setTextColor(WHITE);
display.setCursor(15, 0);
display.print("consigne");
display.drawLine(15, 15, 108, 15, WHITE);
display.setCursor(20, 30);
display.print("C");
display.display();
default:
switch (parametres) {
case 1:
display.print("Parametres");
display.print(">");
display.setCursor(12, 20);
display.print("D. ambiant:");
display.setCursor(96, 20);
display.print(dAmbiant);
display.setCursor(12, 30);
display.print("D. plancher:");
display.setCursor(96, 30);
display.print(dPlancher);
display.setCursor(12, 40);
display.print("Min. ambiant:");
display.setCursor(96, 40);
display.print(minAmbiant);
display.setCursor(12, 50);
display.print("Max. ambiant:");
display.setCursor(96, 50);
display.print(maxAmbiant);
if (parametres == 1 && LastButtonPressed == 4) {
display.setTextColor(BLACK, WHITE);
display.print(">");
display.display();
case 2:
display.setCursor(0, 30);
display.print(">");
if (parametres == 2 && LastButtonPressed == 4) {
display.print(">");
display.display();
case 3:
display.setCursor(0, 40);
display.print(">");
if (parametres == 3 && LastButtonPressed == 4) {
display.print(">");
display.display();
case 4:
display.setCursor(0, 50);
display.print(">");
if (parametres == 4 && LastButtonPressed == 4) {
display.print(">");
display.display();
case 5:
display.print(">");
display.setCursor(12, 0);
display.print("Min. plancher:");
display.setCursor(96, 0);
display.print(minPlancher);
display.setCursor(12, 10);
display.print("Max. plancher:");
display.setCursor(96, 10);
display.print(maxPlancher);
display.print("C. Plancher");
if (parametres == 5 && LastButtonPressed == 4) {
display.print(">");
display.display();
case 6:
display.setCursor(0, 10);
display.print(">");
if (parametres == 6 && LastButtonPressed == 4) {
display.print(">");
display.display();
case 7:
display.print(">");
if (parametres == 7 && LastButtonPressed == 4) {
display.print(">");
display.display();
default:
if (Serial1.available())
if (Serial1.read() == 'I')
int Slave1 = Serial1.parseInt();
if (Slave1 == Sl1)
char command = Serial1.read();
if (command == 'L')
if (Serial1.read() == 'F')
Serial1.print("i");
Serial1.print("6");
Serial1.print(th1);
Serial1.print("a");
Serial1.print(tath);
Serial1.print("p");
Serial1.print(tpth);
Serial1.print("f");
Serial1.flush();
tath = sensors.getTempC(S1);
tpth = sensors.getTempC(S2);
delay(10);
wiring diagram for rs485
