RS232 Aanderaa Conductivity sensor to Arduino
Hi all
I am on a project to make an instrument to measure salinity at Artic glaciers. We have implemented multiple I2C sensors to do so, but want a new sensor attached for benchmark. However I have problems communicating with it, so I hope you can help me. I am using an Arduino Mega and serial communication.
I am using the Breakout - MAX3232 (SparkFun Transceiver Breakout - MAX3232 - BOB-11189 - SparkFun Electronics).
I have attached a picture of the wiring: Yellow to sensor = RS-232-RXD, green to sensor = RS-232-TXD
The sensor I am using is the Aanderaa Conductivity Sensor 4319.
Datasheet for sensor: https://www.aanderaa.com/media/pdfs/TD263-Condcutivity-sensor-4319.pdf
The specific RS232 protocol is explained from page 27 and forward.
I have some limited experience with the serial/UART communication. I have tried setting up the attached code, but all I get in return is -1's so it is obviously not working. Have you guys any advice for me?
Thanks in advance. Let me know if you need more information.
Best
Lucas Sandby (Stud. Mech. Eng.)
#define CondSerial Serial3
char message;
  // Start the console serial port
  while (!Serial);
//Starter C-sensor
  CondSerial.begin(9600);
if(CondSerial.available()>0) {
  message = CondSerial.read();
  Serial.print(message);
CondSerial.write("Do Sample\r\n");
Serial.println(CondSerial.read());
Cond_test.ino (405 Bytes)
you need to check if something is available before reading (moved/modified your code from setup() to loop(). assume it generates a linefeed
char message;
  while (!Serial);
//Starter C-sensor
  if(CondSerial.available ()>0) {
    Serial.print (CondSerial.read());
not sure what causes the sensor to generate output
Thanks gcjr. I have tried that, so it probably is the syntax/protocol which is wrong, but I think I can manage to figures that out somehow.
But to look at the code for another sec:
So the datasheet says, that the string "Get Data" terminated by Carriage Return and Line Feed will cause the sensor to generate an output. I want it to do that for like every second or so. Shouldn't it be like:
char message;
  while (!Serial);
//Starter C-sensor
  CondSerial.write("Get Data \r\n");
what happens if characters are sent during the delay and overflow the serial buffer
    while (!Serial);
    //Starter C-sensor
    static unsigned long msecLst = 0;
           unsigned long msec    = millis();
    // send request every second
#define ONE_SECOND 1000
    if (msec - msecLst > ONE_SECOND)  {
        msecLst = msec;
    // wait for response
    if (CondSerial.available ()>0) {
So true. I believe the coding should be okay, but I still have no response from the sensor. Could it have something to do with the setup. The datasheet says:
The following RS-232 setup should be used:
9600 Baud (which I have set i up through the serial port)
8 Data bits
1 Stop bit
No Parity
Xon/Xoff Handshake
The parity, stop- and data bits are not entered anywhere, but I guess it is included in the serial.write/read?
If it still doesn't work this is correct it must be my way of writing to the sensor, which is wrong.
I appreciate your help
Best
describe all the pins you've connected between the Arduino and sensor and the power supply pins?
