I have a Denon receiver, who refuses functioning properly within the Lan-Network with my FritzBox. So I decided to communicate using a RS232 connection.
I bought a Max232 module including resistors, capacitors and so on, f.e.see this ebay link
3,3 - 5V operation range.
I started with an ESP32 (as it has several hardware RX TX ports), checked if communication is fine with an Arduino Nano. Then, after connecting to the RS232, I get the "system messages" of the AVR if I f.e. change the volume.
Problem is: I cannot send.
Here you can see the Denon datasheet of RS232 /Lan interface
I have set up a 9600 SERIAL_8N1 connection, as required.
Now I am searching for hours, with no conclusion. All I found was a dutch(?) conversation about connecting to a Maranz AVR, which is same company as Denon. Close to the end, it says
//POWER OFF
Serial.write("@");
Serial.print("VOL:1");
Serial.write("\r\n");
works fine for him. According to the Maranz Code List the string is different, the @ is added, however, carriage return is also necessary.
So I tried a lot:
Ser2.print("MVUP");
Ser2.print("MVUP\r");
Ser2.print("MVUP\r\n");
Ser2.write("MVUP");
Ser2.write("MVUP\r");
Ser2.write("MVUP\r\n");
Ser2.println("MVUP");
Ser2.println("MVUP\r");
Ser2.println("MVUP\r\n");
and much more (also according to the example of the Maranz user) - zero effect.
Also, to ensure the problem is not ESP-related (3,3V f.e.), I have set up an Nano with the same code snippet. Again, the AVR does nothing.
Has anyone a Denon himself or sees what I am doing wrong here?
