RS232 projector remote
Hello, i try without success to change my projector from a vivitek to a nec
I have a very simple arduino program to do that.
For my vivitek i use Serial.println("~PN"); for ON command
For a sanyo i use Serial.println("C00");
For a nec projector the ON command is 02h 00h 00h 00h 00h 02h
I have tried Serial.println("02 00 00 00 00 02"); and many other things but without success.
My serial rate are right.
When i read the string with a sniffer i received the same string but not in this form.
Have you a idea to send exactly 02 00 00 00 00 02 in this form?
Thanks
Denis
And excuse my poor english, i'm french speaker
So, 6 bytes of 2, 0, 0, 0, 0, 2.
I have tried Serial.println(“02 00 00 00 00 02”);
I can’t imagine why you think that sending a string, when the device expects 6 bytes, is going to accomplish anything.
Create a 6 element byte array, with the above values, and Serial.write() the array.
You want to send : 02 00 00 00 00 02 from UNO to your remote Projector using RS232 Protocol. You expect that the Projector should receive exactly the same array.
1. The available commands of RS232 Protocol to transfer data are:
Serial.print();
Serial.write():
2. Look at the following Table:
Command Executed        UNO Sends                                           Projector Receives
Serial.print("A");            0x41 (ASCII Code of A)                         0x41
Serial.print("0");            0x30 (ASCII Code of 0)                          0x30
Serail.print("02");           0x30  (ASCII Code of 0)                         0x30
                                    0x32 (ASCII Code of 2)                          0x32
Serial.write(0x02);          0x02  (8-bit natural binary 00000010)      0x02
3. Based on Post#1, we can write the following codes to transmit : 02 00 00 00 00 02
byte dataArray[6] = { 0x02, 0x00, 0x00, 0x00, 0x00, 0x02};
for(int i = 0; i<6; i++)
   Serial.write(dataArray[i]);        //do not expect to see the values in your local Serial Monitor
Even simpler:
byte dataArray[6] = { 0x02, 0xx00, 0x00, 0x00, 0x00, 0x02};
   Serial.write(dataArray, 6);
GolamMostafa:
Serial.print();
Serial.write():
Serial.print(“A”);            0x41 (ASCII Code of A)                         0x41
Serial.print(“0”);            0x30 (ASCII Code of 0)                          0x30
Serail.print(“02”);           0x30  (ASCII Code of 0)                         0x30
**3.** Based on Post#1, we can write the following codes to transmit : 02 00 00 00 00 02
Or, if you’re not being paid by the line-of-code
const byte dataArray[6] = { 0x02, 0xx00, 0x00, 0x00, 0x00, 0x02};
   Serial.write(dataArray, sizeof (dataArray));
TolpuddleSartre:
Or, if you're not being paid by the line-of-code
PaulS:
Even simpler:
I would prefer @Pauls (only one character instead of 18)?
SOLVED and thanks to everybody
GolamMostafa:
Spoken like a true noob.
GolamMostafa:
If the size of the array changes, the hardcoded value will be wrong. The sizeof() method will not.
As long as you are careful, there won't be a problem. But, one mistake...
Another question. I try a Optoma projector to check my remote.
The string for ON is ~XX00 1 or 7E 30 30 30 30 20 31 0D
I try :
byte dataArray[8] = {0x7e,0x30, 0x30, 0x30, 0x30, 0x20, 0x31, 0x0d};
Serial.write(dataArray, 8);
And nothings append.
Have you a idea
Many Thanks
The ASCII value for the ~ is 0x7E. The ASCII value for the space is 0x20. The ASCII value of the 1 is 0x31. The character whose ASCII value is 0x30 is the ‘0’.
So, the HEX values you show do NOT correspond to the string that you show.
It's my error the good string is ~0000 1
In my exemple XX was the ID of projector, ID 00 is for all projector
So, why not just print "~0000 1"?
I have try without success.
I have tried Serial.println("~0000 1");
or Serial.print("~0000 1");
or Serial.write("~0000 1");
but nothing
When i send :
I receive on sniffer : ~0000 1 ( that’s good)
But no response from projector
But if i send the same string 7E 30 30 30 30 20 31 0D from a laptop, the projector goes on without problem
How are you sending data from the laptop?
The string "7E 30 30 30 30 20 31 0D" is nowhere near the same as the string "~0000 1" or the byte array 0x7e, 0x30, 0x30, 0x30, 0x30, 0x20, 0x31, 0x0d.
from a nice free program call comtools from sonelec, french programmer
denis114:
Open source, or executable only? Link?
old program executable :Logiciels - Freewares - ComTools
I think the problem is the space in :"~0000 1"
because when i send it, i receive ~00001 on the computer
How to add a "space" ?
denis114:
You add a space to a string by pressing the space key.
It really would be helpful if you explained how you are receiving this data. However it is, that is the process that is loosing the space.
