RS232 to TTL Converter PCB
Hey guys,
I've made a PCB design that should convert he old RS232 (de9) to TTL (rx tx). DTR pin included for auto reset feature.
I think I made it good and small. I just want to share some thoughts and maybe someone could tell me if it's going to work.
Included is a Board and schematic files for Eagle.
http://www.mediafire.com/?nfc8s40ec8obecn (old)
http://www.mediafire.com/?xx81hcxt18reubc (updated thanks to westfw)
It would be great if someone could give me some advices or suggestions to make it better.
Thank you very much.
fail, get a webhost I have no idea what I am downloading off of rapid extreme share blah blah bull
I pay 5$ a month for mine, and it has a Tb of bandwidth, there are plenty of free alternatives
well you could've just said it was fail...I choose whatever found on google...
I'll repost the link....
Too bad I can't just attach the file through my post....
It's got problems:
GND isn't connected to the DB9.
D1 has it's terminals shorted.
Traces zig-zag all over the board when there are obvious shorter paths.
R5 right pin is too close to the output pad.
Resistors are too tiny (maybe), diodes are too big (looks like power rectifier package! (Is!))
thanks for the advice.. ;D
I'll try to fix it....
UPDATE : I've fix it. I think it look better.
Link brd and sch file : http://www.mediafire.com/?xx81hcxt18reubc
Hmm.
The board and schematic are "inconsistent"; you need to fix that first. make sure that the "class" contents are the same, and make sure that the serial connector has the same value in both schematic and board. At that point, run the ERC and make sure it says that they are consistent, so that edits in the schematic will show up in the board as well (and vis versa, for certain types of changes in the board.) (always edit with both board and sch open. It's much easier to avoid the dreaded inconsistency than to fix it.)
You connected GND to pin 5 of the DB9 more securely on the .BRD, but it isn't connected in the schematic.
Use a pin-header from the "pinhead" library for your off-board connections. For this board, you should probably use 5 one-pin pinheaders that can be moved independently, rather than one 5-pin connector.
D1 still has a wire/signal between its pins...
It still has zig-zagged connections. Do you understand that every point on a copper trace is electrically identical (for practical purposes, anyway.) You do not have to connect the pins in the same order they are connected on the schematic, as long as all the pins connected are on the same trace somewhere. For example, here is what I did to GND:
There is a similar problem for the signal on pin 3 of the DB9.
Awesome....thanks !!!
I'm just beginning my way in the eagle stuff and Iit looks like I have a lot to learn.... :stuck_out_tongue:
UPDATE: I've fixed it and get to move the components closer. I've check the board and the schematic side by side and now I've got everything connected.
Thanks !!!
Will try to make it asap and see if it works...
