I want to realise a transmission with 2xmax485 for 422 full duplex communication (TX+/TX-/RX+/RX-)
Is this schéma is ok for you. The length of the line will be < 10meters
Is it necessary or better to use optocopler like 4N28 ?
Thanks for your comments.
It looks fine. You should not need or want opto-couplers. You want something designed to overcome the influence of wire length... and these chips do that.
Thanks for a so speed answer ! I will realize that circuit.
I will tell you you more when my project will be efficient !
Grag38
