I have some troubles using a Mega with RS485 modules.
When using the same code with 2 Arduino Uno, no problem i'm receiving the "ok"
Now with 2 Megas, nothing happens
Thanks for your help!
#include "RS485_protocol.h"
#include <SoftwareSerial.h>
const byte ENABLE_PIN = 4;
const byte LED_PIN = 13;
SoftwareSerial rs485 (2, 3); // receive pin, transmit pin
// callback routines
void fWrite (const byte what)
rs485.write (what);
rs485.begin (28800);
pinMode (ENABLE_PIN, OUTPUT); // driver output enable
pinMode (LED_PIN, OUTPUT); // built-in LED
} // end of setup
byte old_level = 0;
// assemble message
byte msg [] = {
15 // device 1
// turn light on
// send to slave
digitalWrite (ENABLE_PIN, HIGH); // enable sending
sendMsg (fWrite, msg, sizeof msg);
digitalWrite (ENABLE_PIN, LOW); // disable sending
} // end of loop
rs485.write (what);
int fAvailable ()
return rs485.available ();
int fRead ()
return rs485.read ();
byte buf [10];
byte received = recvMsg (fAvailable, fRead, buf, sizeof (buf));
if (received)
if (buf [0] == 15)
Serial.print("ok!!");
} // end of loop
