RS485 and some Arduinos
Hello all,
I nedd a good tutorial to connect some Arduinos with RS485, in my interface I am using the max485.
thank you for the help,
You can follow the link:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245014666
Sorry, it´s in spanish
Regards,
Igor R.
Thank you very much Igor, that solved my problem.
(PS No problem I speak spanish)
Regards,
I just started working on an RS485 design myself, using newsoftserial9.
I just built an RS232-RS485 adapter for the PC. I'm looking to string a number of devices together using the multi-drop capabilities of RS485.
I don't speak Spanish... so if you end up doing things you can share... that would be great.
pwillard
maybe this can help you
http://gdallaire.net/blog/?p=39
regards,
Thanks... but he was being real sketchy about how he got it working... and for some reason his routines would cause my arduino to reset when used with newsoftserial9. I didn't have the desire to debug the reason why... so I started over. (He was an inspiration though).
Igor's stuff is much more interesting.
If I have some free time, I´ll traduce it.
Regards,
Igor R.
"...Igor's stuff is much more interesting."
I agree with you Pwillard and Igor is very, very helpfull.
I am discussing some ideas with him in the international forum.
Regards,
I´ve just finish one example. There are 3 Arduinos, one master and two slaves.
The slaves have a led in their pin 13.
The control of switch on/off is with 2 buttons from Master.
Here you can see a photo:
And the video working:
A diagram of the protocol:
It´s based on a proffesional machine: http://www.cdautomation.com/download/ENG_L_M_FUJI_RS485_COMM_for_FRENIC-Mini.PDF
It´s important the lenght of the conecttion from transceiver (MAX485 or 75176) to the bus be as short as possible. I always do my connections like the photo (black and white are the bus).
Now, It´s easy do my own functions to control an arduino network. I´ve prefered use something based on a professional machine, because for sure my applications will be easiers.
To see the data in the bus,you can use RealTerm http://realterm.sourceforge.net/. It´s free and you can see hex and ascii data.
You can see the code of this example ==> http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245014666/15#15
Regards,
Igor R.
Igor: Nice Work!
Do you have a schematic view of your 485 converter? I can recognize the max485 and a resistor but what is it on the top right corner? is it a voltageregulator?
Thanks
//Daniel
It´s just a jumper to add/remove the resistor...
Regards,
Igor R.
