RS485 BOB 10124 Random behaviour
Hello all,
I am a little stuck with my project and i was hoping to get some sort of input as i got way over my head in this and seems i cannot think right.
So the story:
The problem : I want to connect a solar installation controller to INTERNET, the solar controller communicates via RS485 and i have succesfully implemented the protocol to talk with it via USB 2 RS485.
The designed Solution: I will use ESP8266 Chip to querry the device using a BOB 10124 Breakout board, The loop will query the device every 5 minutes or so and transmit the data via POST to Device.IO/ Fusion.IO or something similar. The request is quite simple on a master - slave type like COMMAND - COMMAND RESPONSE. So the device echoes the command and attaches the answer. First step was to get the code running using an ARDUINO BOARD (MEGA 2560) due to multiple Serials that makes debugging easy
The challenge: It seems i cannot get the RS485 Breakout (BOB 10124) to work. It has a RTS pin for flow control and it works randomly, sending and receiving junk data.
My 2 cents on this issue after 2 weeks on this problem. There is a timing issue regarding sending multiple bytes of data to BOB 10124. Even after using Serial.Flush() - to wait for the serial to end transmission and bring RST LOW in more de 6/10 the transmission is grabled.
I have tried multiple delays to the RST pin but with no succes, sniffing the communications shows the bytes intact, checking with an oscilloscope the wave lenghth of a good and an invalid communication shows no remarcable differences in terms of timings.
P.S In the design RX and Tx are inverted as they should be....
I have tried also with 220 Ohm terminal resistors on each B A also used 1k-4.4k PULL UP - PULL DOWN RESISTORS on each B and A. I tried with or without flush, sending either ascii or byte to the Serial.
I used BOB 10124 Just to receive data from the controller (sent the data using a USB TO RS485) and it works like a charm no errors, no nothing, I send data between BOB and USB TO RS485 in both directions and also it works without an issue. So the only thing remaining was the transmision to the solar controller. One way or another the RTS pin triggers instability and i cannot seem to stabilize the line. The backup plan is to switch to a MAX 13487/13488 Chip for this but i was hoping that maybe some of you had this issue and find out a fix.
Thank you
The answer received from the controller are something like this:
05:56:23: ADS123:TEMP1
ADS123:TEMP2 23
05:56:33: ADS123:TEMP2
05:56:43: ADS123:TEMP1
05:56:54: ADS123:TEMP2
ADS123:TEMP2 23
05:57:04: ADS123:TEMP1
ADS123:ERROR
05:57:14: ADS123:TEMP2
ADS123:ERROR
05:57:24: ADS123:TEMP1
05:57:34: ADS123:TEMP2
05:57:44: ADS123:TEMP1
ADS123:TEMP1 22
05:57:54: ADS123:TEMP2
ADS123:ERROR
05:58:04: ADS123:TEMP1
The code used for this test is :
byte Data[200];   // array to store data
byte index;   // array index
byte readByte = 0; //variable to store byte
int counter = 0;
int scout = 0;
boolean headerCheck = true;
boolean arrayFilled = false;
#define pin 3
//Use to trigger device querry
const long interval = 1000;
unsigned long previousMillis = 0;
//41 44 53 31 32 33 3A
//A  D  S   1  2  3  : // Header bytes for valid answers
 // initialize serial communications at 9600 bps:
 Serial2.begin(9600);
 pinMode(pin, OUTPUT);
byte a[]={0x41, 0x44 ,0x53, 0x31, 0x32 ,0x33, 0x3A ,0x54, 0x45, 0x4D, 0x50, 0x31, 0x20, 0x0D, 0x0A};
int k=0;
  if (currentMillis - previousMillis >= 10000)
        //digitalWrite(pin, HIGH);
        //delayMicroseconds(25);
       /** Serial2.end();
        Serial2.write(0x41);
        Serial2.write(0x44);
        Serial2.write(0x53);
        Serial2.write(0x31);
        Serial2.write(0x32);
        Serial2.write(0x33);
        Serial2.write(0x3A);
        Serial2.write(0x54);
        Serial2.write(0x45);
        Serial2.write(0x4D);
        Serial2.write(0x50);
        Serial2.write(0x20);
        Serial2.write(0x0D);
        Serial2.write(0x0A);
        Serial2.flush();
        //Serial2.flush();
        delayMicroseconds(120); **/
        if (k==0)
            //Serial2.println("ADS123:TEMP1 ");
            //Serial.println(millis());
            Serial.println("ADS123:TEMP1 ");
            k++;
            //Serial2.println("ADS123:TEMP2 ");
            Serial.println("ADS123:TEMP2 ");
            k=0;
        Serial2.flush();
        // Serial.println(millis());
        //delay(5);
        digitalWrite(pin, LOW);
 if(Serial2.available() > 0)
  byte readByte = Serial2.read();
  Serial.write(readByte);
  switch(counter)
  case 0:   if (readByte==0x41) counter = 1; else counter = 0;   break;
  case 1:   if (readByte==0x44) counter = 2; else counter = 0;   break;
  case 2:   if (readByte==0x53) counter = 3; else counter = 0;   break;
  case 3:   if (readByte==0x31) counter = 4; else counter = 0;   break;
  case 4:   if (readByte==0x32) counter = 5; else counter = 0;   break;
  case 5:   if (readByte==0x33) counter = 6; else counter = 0;   break;
  case 6:   if (readByte==0x3A) counter = 7; else counter = 0;   break;
  case 7 ... 200:   // 39 bytes
      Data[counter-7] = readByte;
      if (readByte==13)
             counter=255;
             //Serial1.end();
             Serial.print(currentMillis);
             Serial.println(" X CR");
       scout++;
       if (counter == 200) counter=255; else counter++;
  case 255:   // rest state after message has been saved, nothing will happen until counter is set to 0
  default:
    counter=0;
    scout=0;
 if(counter == 255)
  Serial.print("   MESSAGE SIZE : " );
  Serial.println(scout);
  Serial.print("START RX HEX: <");
  for(int i=0; i<=scout;i++)
      Serial.print(Data[i],HEX);
      Serial.print(" ");
  Serial.println("> END RX");
  Serial.print("START RX DEC: <");
      Serial.print((char)Data[i]);
  // use data
  counter=0;
  scout=0;
Changed the Max 485 chip with MAX 13487 And still having same issues :(... seems like the transmission is not ok, the receive part works flawlessly and i am back at square 1....
The RTS line is not for flow control but for direction control. Pull it high during transmission, pull it low during reception. In your current code this behaviour is commented out.
The BO 10124 is terminated on-board (220Ω), so use it only at the end of a bus. According to your description you're using it only that way.
Ok, seems i am the only one using this so i could as well update it for the history....
Both Arduino UNO and MEGA were faulty,
Changed them with a OLIMEXINO and things started to work, seeemed to get over the BAD KARMA.
I have reverted to RS485 BREAKOUT, with the RTS pin and to make it work you have to add a delay(1) just before turning RTS LOW otherwise the comm gets truncated, checked it with an osciloscope on B and on TX and the TX took a little longer. Apparently the delay(1) does the trick.
Another great tip was to NOT show results during the transmission on a LCD it inserts faulty delays. So prepare the data, open rts, send the date, flush the serial, insert the delay and after that display whaterver you wish.
This is my saga, hope it helps someone....
Can you describe in more detail what you mean by "faulty"?
As there are several boards called "Olimexino", please provide a link to the one you're using.
You are using this board, aren't you?
I use the same chip on a board that's equivalent to an UNO and that's working great.
Which version of the IDE do you use? The Serial.flush() method changed significantly over the last years. With current IDE code (1.6.13) the delay before turning RTS low shouldn't be necessary anymore as the code blocks until the last bit has left the serial data register (which means the data was completely transfered).
