RS485 communication between master and specific slave
Hello,
I have established a communication network with one master and several slaves (2-5) using RS485.
I have written a code for arithmetic operation where in a master will send a value to slave through its serial monitor (eg:5+10;1) and answer will be displayed in slave’s monitor (eg: 15) which then will be sent back to the master.
My query is that when I connect a second or more slaves to the network, then master sends value to all the slaves. But I want the master to select a particular slave to send the value and to perform operation. Earlier I had used i2c connection with Wire library that had Serial.beginTransmission(slave_number).
Is there anything similar to this in RS485?
Master code:
#include "RS485_protocol.h"
#include <SoftwareSerial.h>
const byte ENABLE_PIN = 2;
SoftwareSerial rs485 (10,11);  // receive pin, transmit pin
char input[10];
char res[10];
int charsRead = 0;
int sl;
boolean received = false;
  //Wire.begin(0);
  rs485.begin (28800);
  pinMode (ENABLE_PIN, OUTPUT);
//Wire.onReceive(receiveEvent);
Serial.flush();
if(Serial.available() == 0)
//delay(200);
while (Serial.available() > 0)
  //delay(100);
// 1 becomes 10 while there is data in the buffer
charsRead = Serial.readBytesUntil('\n', input, sizeof(input)-1);
//input[charsRead] = '\0';
//number = atoi(input);
//Serial.println(number);
//delay(5);
sl = input[charsRead - 1] - '0';
input[charsRead - 1] = '\0';
//Serial.print("You entered: ");
if(charsRead > 0){
  //Serial.println(sl);
Serial.println(input);
digitalWrite (ENABLE_PIN, HIGH);  // enable sending
 rs485.write(input);
digitalWrite (ENABLE_PIN, LOW);
charsRead = 0;
input[0] = 0;
  int i=0;
  //delay(100);
   while(rs485.available()){
    //delay(100);
    char c;
    c = rs485.read();
    res[i++] = c;
    //Serial.println(c);
   received = true;
if(i>0)
  Serial.println(res);
Slave code:
  SoftwareSerial rs485 (10, 11);  // receive pin, transmit pin
boolean replay = false;
 int z = -1;
  pinMode (ENABLE_PIN, OUTPUT); // register event
//Wire.onRequest(requestEvent);
//char number = 0;
    char res[10] = {0};
    char a[5] = {0};
    char b[5] = {0};
    char operation;
    int i = 0;
    char c;
    boolean op2 = false;
   // delay(100);
    c = rs485.read();
   Serial.println(c);
   //delay(10);
      //char c = Wire.read(); // receive byte as a character
      if(c == ';')
        Serial.println("End Received");
        replay = true;
      if(c == '+' || c == '-' || c == '*' || c == '/' || c == '(' || c == ')')
        i = 0;
        op2 = true;
        operation = c;
        continue;
      if(op2)
        b[i++] = c;
        a[i++] = c;
    int x = atoi(a);
    int y = atoi(b);
    //Serial.println(x);
    //Serial.println(y);
    switch(operation)
      case '+':  z = x + y;
      case '-': z = x - y;
       case '*': z = x * y;
       case '/': z = x/y;
       case '(': z = max(x,y);
       case ')': z = min(x,y);
    //Serial.println(z);
      if(z>0){
  itoa(z, res, 10);
//Serial.println(res);
  if(replay){
   rs485.write(res);
  replay=false;
