RS485 issue using SoftwareSerial()
Hi
I have downloaded Nick Gammon code, but are having some compiling issues.
I got it down to 2 errors
//#include "WConstants.h"
#include <RS485_non_blocking.h>
//#include "RS485_protocol.h"
#include <SoftwareSerial.h>
const byte ENABLE_PIN = 4;
const byte LED_PIN = 13;
SoftwareSerial rs485(2, 3);  // receive pin, transmit pin
// callback routines
void fWrite (const byte what)
  rs485.print (what);
int fAvailable ()
  return rs485.available ();
int fRead ()
  return rs485.read ();
  rs485.begin (28800);
  pinMode (ENABLE_PIN, OUTPUT);  // driver output enable
  pinMode (LED_PIN, OUTPUT);  // built-in LED
}  // end of setup
byte old_level = 0;
  // read potentiometer
  byte level = analogRead (0) / 4;
  // no change? forget it
  if (level == old_level)
    return;
  // assemble message
  byte msg [] = {
     1,    // device 1
     2,    // turn light on
     level // to what level
  // send to slave
  digitalWrite (ENABLE_PIN, HIGH);  // enable sending
  sendMsg (fWrite, msg, sizeof msg);
  digitalWrite (ENABLE_PIN, LOW);  // disable sending
  // receive response
  byte buf [10];
  byte received = recvMsg (fAvailable, fRead, buf, sizeof buf);
  digitalWrite (LED_PIN, received == 0);  // turn on LED if error
  // only send once per successful change
  if (received)
    old_level = level;
}  // end of loop
Errors are:
sketch_jan14a.cpp: In function ‘void loop()’:
sketch_jan14a.cpp:62:35: error: ‘sendMsg’ was not declared in this scope
sketch_jan14a.cpp:67:62: error: ‘recvMsg’ was not declared in this scope
But what do I replace the sendMsg with.
I have looked through the SoftwareSerial.cpp and .h files but nothing springs to mind
Thanks for any suggestions
Kim
sketch_jan14a.cpp:62:35: error: ‘sendMsg’ was not declared in this scope sketch_jan14a.cpp:67:62: error: ‘recvMsg’ was not declared in this scope
Well, they aren't, are they?
A link to where you got the code would be good. That way, we can see whether you got ALL the code. Doesn't look like you did. Or, you were expected to write those functions.
Straight from Nick Gammon site
http://www.gammon.com.au/forum/?id=11428
I guess we'll have to wait for Nick to respond.
PaulS: I guess we'll have to wait for Nick to respond.
In the meantime have a look at post #8 in this thread http://www.gammon.com.au/forum/bbshowpost.php?bbsubject_id=11603
Sorted.
For some reason I commented out
//#include <RS485_protocol.h>
and included
when both should be included.
Sometimes you just can’t see the forest for the trees
Cheers
