Hello,
I am trying to send data from an SD card on one arduino to another arduino using RS485. I have been slowly adding to the code below and currently know it can read data from the SD card correctly and that the RS485 is wired up correctly. I have managed to get single numbers to bounce between the two using example codes online. Ideally I am trying to send a "float" or an "int" however I have spent the day looking online with no success.
Any help would be greatly appreciated.
The code i am using on the transmit side is the:
SD card sending info over RS485
/*-----( Import needed libraries )-----*/
#include <SoftwareSerial.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define RS485rx 7 // RS485 Receive pin
#define RS485Tx 8 // RS485 Transmit pin
#define RS485inout 3 // RS485 Transmit or Receive status
#define RS485Transmit HIGH
#define RS485Receive LOW
#define ledPin 13
#define baudRate 115200
/*-----( Declare objects )-----*/
SoftwareSerial RS485(RS485rx, RS485Tx); // RX, TX
/*-----( Declare Variables )-----*/
int check;
/*-----( SD Card )-----*/
#include <SPI.h>
#include <SD.h>
File myFile;
const int chipSelect = 10;
float T; // Checking temp previous
float P1; // Checking temp previous
float test;
int i;
int z;
/*+++++++++++++++++++++++++++++++ RTC Setup +++++++++++++++++++++++++++++++*/
#include "RTClib.h"
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
int Sec;
// SETUP SETUP SETUP SETUP SETUP
void setup() { /****** SETUP: RUNS ONCE ******/
/*-----( RS485 )-----*/
pinMode(RS485inout, OUTPUT);
// Set RS485 device to read initially
digitalWrite(RS485inout, RS485Receive);
// MUST BE THE SAME AS THE SENDER UNIT!
RS485.begin(baudRate);
pinMode(chipSelect, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("TEST1.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.println("Worked...");
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
/*+++++++++++++++++++++++++++++++ RTC Start Up +++++++++++++++++++++++++++++++*/
rtc.begin();
// LOOP LOOP LOOP LOOP LOOP LOOP LOOP
/*-----( SD Card Code )-----*/
myFile = SD.open("TEST1.txt");
if (myFile) {
File TEST1; // The file with your data in it.
/*-----( For loop which now continuosly runs )-----*/
//for (i=0; i < 8000; i=i+19){
for (i=0; i < 98000; i=i+19){
//if(Sec==00||Sec==05||Sec==10||Sec==15||Sec==20||Sec==25||Sec==30||Sec==35||Sec==40||Sec==45||Sec==50||Sec==55){
DateTime now = rtc.now();
Sec = ((now.second()));
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println(i);
uint32_t fileSize = myFile.size();
myFile.seek(fileSize - (fileSize-i));
char temp [9];
char oldRecord [18];
myFile.read(oldRecord, 18); // Read 18 bytes.
oldRecord[18] = 0; // Null termination (may not be needed)
strncpy(temp, oldRecord, 9); // Read 9 characters from line starting at the 1st character and copy this into char array temp.
T = atof(temp);
Serial.println("Temp");
Serial.println(T,4);
char press1 [9];
strncpy(press1, oldRecord + 9, 9);
P1 = atof(press1);
Serial.println("Pressure");
Serial.println(P1,4); // print the first 4 digits
/*-----( Should make RS485 Transmit )-----*/
// Set the RS485 to transmit mode and send the value
digitalWrite(RS485inout, RS485Transmit);
check = (P1);
RS485.write((check));
//check = String(P1);
//check = (P1,3);
Serial.println("check");
Serial.println((check));
delay(abs(5000));
The receiving side has the following very simple code:
#define SSerialRX 00 //Serial Receive pin
#define SSerialTX 01 //Serial Transmit pin
#define SSerialTxControl 3 //RS485 Direction control
#define Pin13LED 10
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
int byteReceived;
int byteSend;
void setup() /****** SETUP: RUNS ONCE ******/
// Start the built-in serial port, probably to Serial Monitor
Serial.println("SerialRemote"); // Can be ignored
pinMode(Pin13LED, OUTPUT);
pinMode(SSerialTxControl, OUTPUT);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
// Start the software serial port, to another device
RS485Serial.begin(4800); // set the data rate
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
//Copy input data to output
if (RS485Serial.available())
byteSend = RS485Serial.read(); // Read the byte
delay(10);
Serial.println(byteSend);
}// End If RS485SerialAvailable
}//--(end main loop )---
