Hi, I’m having a bit of a problem with a project to use RS485. I’m new to arduino and I’m trying to write code that will allow me to have a remote arduino which has a DHT11 sensor for temperature and humidity and a LDR for Lux readings. Because of the distance I want to use rs485 protocol to connect this arduino to another arduino and serial print the DHT and Lux value from the remote arduino. The code is as follows (Master):
//RS485 Master program for DHT and Lux values
/*-----( Import needed libraries )-----*/
#include <SoftwareSerial.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define SSerialRX 10 //Serial Receive pin
#define SSerialTX 11 //Serial Transmit pin
#define SSerialTxControl 3 //RS485 Direction control
#define RS485Transmit HIGH
#define RS485Receive LOW
#define Pin13LED 13
#include <DHT11.h>
// DHT
#define DHTTYPE DHT11 //define which DHT chip used - DHT11
/*-----( Declare objects )-----*/
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
/*-----( Declare Variables )-----*/
int byteReceived;
int byteSend;
byte bGlobalErr; //for passing error code back.
byte dht_dat[4]; //Array to hold the bytes sent from sensor.
float Lux; // |
void setup() /****** SETUP: RUNS ONCE ******/
// Start the built-in serial port, probably to Serial Monitor
pinMode(Pin13LED, OUTPUT);
pinMode(SSerialTxControl, OUTPUT);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
// Start the software serial port, to another device
RS485Serial.begin(4800); // set the data rate
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
digitalWrite(Pin13LED, HIGH); // Show activity
if (Serial.available())
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit for temperature
RS485Serial.write('A');
delay(10);
RS485Serial.write('Temp');
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit for temperature
byteReceived = Serial.read();
if ('Temp' == byteReceived)
Serial.write("Temp = "); // Send Temp back
Serial.write(dht_dat[2]); // Send Temp back
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit for humidity
delay(10);
RS485Serial.write('Humidity');
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit for Humidity
if ('Humidity' == byteReceived)
Serial.write("Humidity = "); // Send Humidity back
Serial.write(dht_dat[0]); // Send Humidity back
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit for Lux
delay(10);
RS485Serial.write('Lux');
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit for Lux
if ('Lux' == byteReceived)
Serial.write("Lux = "); // Send Lux back
// Serial.write(Lux);
digitalWrite(Pin13LED, LOW); // Show activity
delay(10);
//if (RS485Serial.available()) //Look for data from other Arduino
// digitalWrite(Pin13LED, HIGH); // Show activity
// byteReceived = RS485Serial.read(); // Read received byte
// Serial.write(byteReceived); // Show on Serial Monitor
// delay(10);
// digitalWrite(Pin13LED, LOW); // Show activity
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//NONE
//*********( THE END )***********
The code for the remote/slave device:
// Include RHT Library Code
#include <DHT11.h>
#define Pin13LED 13
// DHT
#define dht_dpin 69 //pin for DHT11 (Actual pin 15)
//Light Sensor
int lightSensor = 68; //pin for Photoresistor
int byteReceived;
int byteSend;
int lightADCReading; //variables for measuring the light
double Lux; // |
double lightInputVoltage; // |
double lightResistance; // |
void setup() //Every block is in a separate function.
pinMode(dht_dpin,OUTPUT);
digitalWrite(dht_dpin,HIGH);
Serial.println("SerialRemote"); // Can be ignored
fotoLoop(); //Light measurements loop through this one
ReadDHT(); //Temperature and Humidity Readings
//Copy input data to output
byteSend = RS485Serial.read(); // Read the byte
delay(100);
//if (-1 != byteSend)
if ('A' == byteSend)
if ('Temp' == byteSend)
RS485Serial.write(dht_dat[0]); // Send Temp back
if ('Humidity' == byteSend)
RS485Serial.write(dht_dat[2]); // Send Humidity back
if ('Lux' == byteSend)
RS485Serial.write(Lux); // Send Lux back
delay(100);
//digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit
// delay(100);
}// End If RS485SerialAvailable
Serial.print("LUX = ");
Serial.println(Lux);
Serial.print("Humidity = ");
Serial.println(dht_dat[0]);
Serial.print("Temp = ");
Serial.println(dht_dat[2]);
delay(2500);
void ReadDHT()
bGlobalErr=0;
byte dht_in;
byte i;
digitalWrite(dht_dpin,LOW);
delay(23);
delayMicroseconds(40);
pinMode(dht_dpin,INPUT);
dht_in=digitalRead(dht_dpin);
if(dht_in)
bGlobalErr=1;//dht start condition 1 not met
return;
delayMicroseconds(80);
if(!dht_in)
bGlobalErr=2;//dht start condition 2 not met
return;
for (i=0; i<5; i++)
dht_dat[i] = read_dht_dat();
byte dht_check_sum =
dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
if(dht_dat[4]!= dht_check_sum)
bGlobalErr=3;
byte read_dht_dat()
byte i = 0;
byte result=0;
for(i=0; i< 8; i++)
while(digitalRead(dht_dpin)==LOW);
delayMicroseconds(45);
if (digitalRead(dht_dpin)==HIGH)
result |=(1<<(7-i));
while (digitalRead(dht_dpin)==HIGH);
return result;
void fotoLoop()
lightADCReading = analogRead(lightSensor);
// Calculating the voltage of the ADC for light
lightInputVoltage = 5.0 * ((double)lightADCReading / 1024.0);
// Calculating the resistance of the photoresistor in the voltage divider
lightResistance = (10.0 * 5.0) / lightInputVoltage - 10.0;
// Calculating the intensity of light in lux
Lux = 255.84 * pow(lightResistance, -10/9);
Currently I’m not getting any data from the DHT11 or LUX sensors over the rs485 network. Any help would be greatful
Regards
Anthony
