RS485 MODBUS ARDUINO: Print multiple response data frame from soil sensor
Thanks for your time. The output is every 10 ms
Bad CRC
0E8FB283E000E900046000000B18EFEFB0F3FC0F0
No problem. I really appreciate your help. I'll check both of them to get the rigth values :slight_smile:
What do you mean every 10mS? Is it literally just spamming the serial monitor at 100Hz?
I'm only sending TX requests once every 3-seconds (3000mS). At 4800-bps an 8-byte request message (that is:
requestframe[] = { 0x01, 0x03, 0x00, 0x00, 0x00, 0x07 } plus 2 CRC bytes
takes over 16.6mS to transmit alone. I'm confused because to get to the Bad CRC part it had to have transmitted a request and received a response; this happens every 3-seconds. Even if that timing was bad the TX and RX would take much longer than 10mS.
Just need clarification. Can you post the code you're using right now, even if it's a "copy" of what I (or others) have sent?
Dear @Blackfin. I'm working with your code that you provide me:
#include <Wire.h>
#include <SoftwareSerial.h>
#define RE 8
#define DE 7
// RS485 RE signal to pin 8
// RS485 DE signal to pin 7
// RS485 DI signal to pin 3
// RS485 RO signal to pin 2
#define RX_BUFF_SIZE    30
enum RS485States
    ST_IDLE = 0,
    ST_RXDATA,
    ST_CHECKDATA
const uint16_t crc16_tab[] PROGMEM =
    0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241,
    0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440,
    0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40,
    0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841,
    0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40,
    0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41,
    0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0, 0x1680, 0xD641,
    0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040,
    0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240,
    0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441,
    0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41,
    0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840,
    0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41,
    0xEE01, 0x2EC0, 0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40,
    0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640,
    0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041,
    0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240,
    0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441,
    0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41,
    0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840,
    0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41,
    0xBE01, 0x7EC0, 0x7F80, 0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40,
    0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640,
    0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041,
    0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241,
    0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440,
    0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
    0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841,
    0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40,
    0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41,
    0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641,
    0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040
const byte requestframe[] = { 0x01, 0x03, 0x00, 0x00, 0x00, 0x07 };   //CRC is added in TX logic
uint8_t values[RX_BUFF_SIZE];
SoftwareSerial mod(2,3); // RX, TX ( Creates a new SoftwareSerial object ) (for Uno)
//SoftwareSerial mod(10,3); // RX, TX ( Creates a new SoftwareSerial object ) (for Mega2560)
    Serial.begin(4800);
    mod.begin(4800);
    pinMode(RE, OUTPUT);
    pinMode(DE, OUTPUT);
}//setup
    ModSM();
}//loop
void ModSM( void )
    static uint32_t
        tFrame = 0ul,
        tSM = 0ul;
    static uint8_t
        dataLen,
        rxIdx,
        state = ST_IDLE;
    uint16_t
        crc;
    uint32_t
        tNow = millis();
    uint8_t
        ch;
    switch( state )
        case    ST_IDLE:
            if( (tNow - tSM) >= 3000ul )
                //flush any stray characters from RX buffer
                while( mod.available() )
                    mod.read();
                tSM = tNow;
                digitalWrite(DE, HIGH);
                digitalWrite(RE, HIGH);
                delayMicroseconds(100);
                crc = CRC16_Modbus( requestframe, sizeof( requestframe ) );
                mod.write( requestframe, sizeof(requestframe) );
                mod.write( crc & 0xff );
                mod.write( (crc >> 8) & 0xff );
                delayMicroseconds(10);
                digitalWrite(DE, LOW);
                digitalWrite(RE, LOW);
                rxIdx = 0;
                dataLen = 0;
                state = ST_RXDATA;
            }//if
        case    ST_RXDATA:
            if( mod.available() )
                ch = mod.read();
                switch( rxIdx )
                    case    0:  //address code
                    case    1:  //function code
                        //do nothing but store these
                        values[rxIdx++] = ch;
                    case    2:
                        //number of data + CRC bytes to follow
                        dataLen = ch;
                    default:
                        //RX data and CRC
                        if( rxIdx == RX_BUFF_SIZE )
                            rxIdx--;
                        dataLen--;
                        if( dataLen == 0 )
                            state = ST_CHECKDATA;
                }//switch rx index
            }//if available
        case    ST_CHECKDATA:
            //data done; check the CRC
            for( crc=0; crc<rxIdx; crc++ )            //<--- add
                Serial.print( values[crc], HEX );  //<--- add
            Serial.println(); // <-- add
            crc = CRC16_Modbus( values, values[2]+1 );    //-2 for CRC, +2 for header, +1 for value[2] itself
            if( ((uint8_t)(crc & 0x0ff) == values[rxIdx-2]) && ((uint8_t)((crc>>8) & 0x0ff) == values[rxIdx-1]) )
                //msg is good; print results
                PrintData();
            }//if
            else //<--- add from here...
                Serial.println( "Bad CRC" );
            }//else //<--- to here
    }//switch
}//ModSM
uint16_t CRC16_Modbus( uint8_t *pData, uint8_t Len )
    //CRC16 calculation
    uint16_t crc = 0xFFFF;
    while( Len-- )
        crc = (crc >> 8) ^ (pgm_read_word(&crc16_tab[(crc ^ *pData++)&0xFF]) );
    return crc;
}//CRC16_Modbus
void PrintData( void )
    int16_t
        val;
    //0 index 3     moisture content
    val = (values[3] << 8) + values[4];
    Serial.print( "Humidity....: " ); Serial.print( (float)val/10.0, 1 ); Serial.println("%");
    //1 index 5     temperature
    val = (values[5] << 8) + values[6];
    Serial.print( "Temperature.: " ); Serial.print( (float)val/10.0, 1 ); Serial.println("oC");
    //2 index 7     conductivity
    val = (values[7] << 8) + values[8];
    Serial.print( "Conductivity: " ); Serial.print( val ); Serial.println("us/cm");
    //3 index 9     PH
    val = (values[9] << 8) + values[10];
    Serial.print( "pH..........: " ); Serial.print( (float)val/10.0 ); Serial.println("");
    //4 index 11    nitrogen content
    val = (values[11] << 8) + values[12];
    Serial.print( "Nitrogen....: " ); Serial.print( val ); Serial.println("mg/kg");
    //5 index 13    phosphorus content
    val = (values[13] << 8) + values[14];
    Serial.print( "Phosphorus..: " ); Serial.print( val ); Serial.println("mg/kg");
    //6 index 15    potassium content
    val = (values[15] << 8) + values[16];
    Serial.print( "Potassium...: " ); Serial.print( val ); Serial.println("mg/kg");
}//PrintData
The OUTPUT Prints often:
Bad CRC
000000013E000E500045000000BDDE000
Bad CRC
Bad CRC
So the message is in there but for some reason there's zero-bytes preceding it. Here's the message with the missing leading-zeros added:
01030E000000E500000045000000000000BDDE
This CRC (0xdebd) is correct. Let me mull the datasheet & code a bit to see if there's a reason for the leading 0s; I do flush the read buffer prior to sending a command so it shouldn't be because there's left over nonsense there.
I'will wating your response :+1:
Added a crude filter to wait for the address and function bytes and also added a message timeout (compiles but not tested):
#include <Wire.h>
#define RE 8
#define DE 7
enum RS485States
    ST_IDLE = 0,
    ST_RXDATA,
    ST_CHECKDATA
char
    szStr[10];
    Serial.begin(4800);
    mod.begin(4800);
}//setup
    ModSM();
}//loop
void ModSM( void )
    static uint32_t
        tFrameTimeout = 0ul,
        tSM = 0ul;
    static uint8_t
        dataLen,
        rxIdx,
        state = ST_IDLE;
    uint16_t
        crc;
    uint32_t
        tNow = millis();
    uint8_t
        ch;
    switch( state )
        case    ST_IDLE:
                    mod.read();
                tSM = tNow;
                delay(20);  //allow msg to go before switching DE & RE
                tFrameTimeout = tNow;    //init message timeout
                rxIdx = 0;
                dataLen = 0;
                state = ST_RXDATA;
            }//if
        case    ST_RXDATA:
                ch = mod.read();
                switch( rxIdx )
                        //an attempt to filter leading zeros in reply
                        //look for 0x01 address code
                        if( ch == 0x01 )
                            //got the address code
                        }//if
                        //if function code is not 0x03, we're misaligned
                        if( ch != 0x03 )
                            rxIdx = 0;
                    case    2:
                        dataLen = ch;
                    default:
                        //RX data and CRC
                            rxIdx--;
                        dataLen--;
                        if( dataLen == 0 )
                }//switch rx index
            }//if available
            //if we haven't completed the message after 1.5-seconds just return to idle state
            if( (tNow - tFrameTimeout) >= 1500ul )
                Serial.println( "Message Timeout" );
                state = ST_IDLE;
            }//if
        case    ST_CHECKDATA:
            //show RXed message
            Serial.print( "Msg: " );
                sprintf( szStr, "%02X", values[crc] );
                Serial.print( szStr );
            }//for
            //check the CRC
                PrintData();
            }//if
            }//else
            state = ST_IDLE;
    }//switch
}//ModSM
    //CRC16 calculation
    while( Len-- )
    return crc;
}//CRC16_Modbus
    int16_t
        val;
    //3 index 9     PH
    Serial.print( "Nitrogen....: " ); Serial.print( val ); Serial.println("units?");
    Serial.print( "Phosphorus..: " ); Serial.print( val ); Serial.println("units?");
    Serial.print( "Potassium...: " ); Serial.print( val ); Serial.println("units?");
}//PrintData
This is the TEST OUTPUT:
Msg: 01030E000000E600000045000000000000
Bad CRC
Bad CRC
Bad CRC
Msg: 01030E000000E500000045000000000000
Bad CRC
Message Timeout
Message Timeout
Message Timeout
Msg: 01032000F70B0000000000000000E00000000000000000000000000000
Bad CRC
Message Timeout
Msg: 01030E000000F200000045000000000000
Bad CRC
Msg: 0103F80000900D0000FF010022800003FC0000006010000000000000C0
Bad CRC
Msg: 01030E000000F100000045000000000000
Bad CRC
Msg: 0103627F020638838AE0AF0002FF0080A0840000FC000015B30700000C
Bad CRC
Msg: 01030E000000F000000045000000000000
Bad CRC
So the bulk of those look okay except they're missing their CRC:
01030E000000E500000045000000000000BDDE // <--- expect this
01030E000000E600000045000000000000           // <--- got this
When I count the bytes in the "expected" message, there are 14 bytes in the message payload and the two CRC bytes are counted separately. This is not what's shown in their datasheet; their response frame on pg 16 of the datasheet seems to show the CRC counts in the byte total.
So to try to address that, try:
                    case    2:
                        dataLen = ch + 2; // <--- change this line to add '2' to the dataLength
Now the OUTPUT looks like this:
Msg: 010304E80800207718
Bad CRC
Message Timeout
Message Timeout
Msg: 01030E000000E900000046000000000000B18E
Bad CRC
Msg: 01030E000000EA000000450000000000008DCA
Bad CRC
Message Timeout
Message Timeout
Message Timeout
Bad CRC
Message Timeout
Msg: 01030E000000E900000045000000000000828E
Bad CRC
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Bad CRC
Bad CRC
Bad CRC
These are interesting because, as received, the CRCs are correct but the code is saying they're not. Let me dig some more...
Take your time, of course. I am grateful for guiding me and I will be attentive to your answer
Can you try changing the line:
to
crc = CRC16_Modbus( values, values[2]+3 );    //+2 for header, +1 for value[2] itself
Now sensor is reading.
Dear @Blackfin I really apreciate your time and help. Is there any other suggestion for this comunication RS485 MODBUS with ARDUINO UNO?
Note that you can copy text from the serial monitor and post it, preferably in code tags. It's much more convenient than a picture.
Do the numbers make sense for your test environment?
Potassium...: 0mg/kg
Msg: 01030E000000ED0000004500000000000097BE
Humidity....: 0.0%
Temperature.: 23.7oC
Conductivity: 0us/cm
pH..........: 6.90
Nitrogen....: 0mg/kg?
Phosphorus..: 0mg/kg
Humidity....: 0.0%
pH..........: 6.90
Humidity....: 0.0%
pH..........: 6.90
Message Timeout
Message Timeout
Humidity....: 0.0%
pH..........: 6.90
If the temperature and humidity is rigth and others will be OK.
It seems like it's doing okay. I wonder why it's showing message timeouts though.
When I send the request I set a time value that will expire 1.5-seconds later unless the logic makes it to the ST_CHECKDATA state first. I don't have a sensor so I don't know if its response time is immediate or if it literally takes that long to respond.
The leading-zeros thing is weird too. It feels like a hack to have to "filter" them out like we do. There may be some weirdness associated with the RE/DE pins and the connection to the Uno receive pin; if the RE pin is set high does the RO pin float or is it pulled-up (I think it is from looking at a pic of the RS485 board you're using but I'm not positive...) Anyway, it might be interesting to find out if this is normal behavior not documented in the datasheet or if there's a problem and a fix.
@Blackfin. This is the testing video: VIDEO - TESTING SOIL SENSOR
Image of RS485:
I characterized the write() method and found that it seems to block, meaning it returns when the bytes have been transmitted. The large 20mS delay probably isn't required and may be interfering with reception of a message from the module (since RE is set high...) so as an experiment, can you change the delay(20) back to delayMicroseconds(100):
                //delay(20);  //allow msg to go before switching DE & RE
                delayMicroseconds(100);  //allow msg to go before switching DE & RE
When I changed to:
delay(100);
the OUTPUT ARE only:
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
Message Timeout
