Rs485 modbus rtu with ds18b20
Hello, I have a problem with reading the ds18b20 after the modbus rtu protocol. If it reads everything from the first data bus, everything works - it tests with the mbus.exe program and the fatek fbs-cm25 converter (I can set the scan rate to 10ms) but by adding each next bus I have to increase the scan rate up to 4000ms to eliminate errors. I will add that I am not a programmer.
#include <SimpleModbusSlave.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#define ONE_WIRE_BUS_1 3      //first bus for one ds18b20
#define ONE_WIRE_BUS_2 4      //second bus for one ds18b20
#define ONE_WIRE_BUS_3 5      //third bus for one ds18b20
#define ONE_WIRE_BUS_4 6      //fourth bus for one ds1b20
#define SENSOR_RESOLUTION 9   //set resoution for ds18b20
OneWire oneWire_in_gas(ONE_WIRE_BUS_1);
OneWire oneWire_out_gas(ONE_WIRE_BUS_2);
OneWire oneWire_in_ciecz(ONE_WIRE_BUS_3);
OneWire oneWire_out_ciecz(ONE_WIRE_BUS_4);
//LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//LiquidCrystal_I2C lcd(0x27, 20, 4);
DallasTemperature sensor_gaz_we(&oneWire_in_gas);
DallasTemperature sensor_gaz_wy(&oneWire_out_gas);
DallasTemperature sensor_ciecz_we(&oneWire_in_ciecz);
DallasTemperature sensor_ciecz_wy(&oneWire_out_ciecz);
   SimpleModbusSlaveV10 supports function 3, 6 & 16.
   This example code will receive the adc ch0 value from the arduino master.
   It will then use this value to adjust the brightness of the led on pin 9.
   The value received from the master will be stored in address 1 in its own
   address space namely holdingRegs[].
   In addition to this the slaves own adc ch0 value will be stored in
   address 0 in its own address space holdingRegs[] for the master to
   be read. The master will use this value to alter the brightness of its
   own led connected to pin 9.
   The modbus_update() method updates the holdingRegs register array and checks
   communication.
   Note:
   The Arduino serial ring buffer is 64 bytes or 32 registers.
   Most of the time you will connect the arduino to a master via serial
   using a MAX485 or similar.
   In a function 3 request the master will attempt to read from your
   slave and since 5 bytes is already used for ID, FUNCTION, NO OF BYTES
   and two BYTES CRC the master can only request 58 bytes or 29 registers.
   In a function 16 request the master will attempt to write to your
   slave and since a 9 bytes is already used for ID, FUNCTION, ADDRESS,
   NO OF REGISTERS, NO OF BYTES and two BYTES CRC the master can only write
   54 bytes or 27 registers.
   Using a USB to Serial converter the maximum bytes you can send is
   limited to its internal buffer which differs between manufactures.
#define  LED 9
// Using the enum instruction allows for an easy method for adding and
// removing registers. Doing it this way saves you #defining the size
// of your slaves register array each time you want to add more registers
// and at a glimpse informs you of your slaves register layout.
//////////////// registers of your slave ///////////////////
enum
  // just add or remove registers and your good to go...
  // The first register starts at address 0
  ADC_VAL,
  PWM_VAL,
  PWM_VAL1,
  PWM_VAL3,
  PWM_VAL4,
  PWM_VAL5,
  PWM_VAL6,
  PWM_VAL7,
  PWM_VAL8,
  HOLDING_REGS_SIZE // leave this one
  // total number of registers for function 3 and 16 share the same register array
  // i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
//  lcd.begin(20,4);
 //   lcd.clear();
  //  lcd.print(" inicjalizacja ");
   // lcd.setCursor(0,1);
   // lcd.print(" prosze czekac ");
   // delay(3000);
    sensor_gaz_we.begin();
    sensor_gaz_wy.begin();
    sensor_ciecz_we.begin();
    sensor_ciecz_wy.begin();
      sensor_gaz_we.setResolution (SENSOR_RESOLUTION);
      sensor_gaz_wy.setResolution (SENSOR_RESOLUTION);
      sensor_ciecz_we.setResolution (SENSOR_RESOLUTION);
      sensor_ciecz_wy.setResolution (SENSOR_RESOLUTION);
     /* parameters(HardwareSerial* SerialPort,
                long baudrate,
    unsigned char byteFormat,
                unsigned char ID,
                unsigned char transmit enable pin,
                unsigned int holding registers size,
                unsigned int* holding register array)
  /* Valid modbus byte formats are:
     SERIAL_8N2: 1 start bit, 8 data bits, 2 stop bits
     SERIAL_8E1: 1 start bit, 8 data bits, 1 Even parity bit, 1 stop bit
     SERIAL_8O1: 1 start bit, 8 data bits, 1 Odd parity bit, 1 stop bit
     You can obviously use SERIAL_8N1 but this does not adhere to the
     Modbus specifications. That said, I have tested the SERIAL_8N1 option
     on various commercial masters and slaves that were suppose to adhere
     to this specification and was always able to communicate... Go figure.
     These byte formats are already defined in the Arduino global name space.
  modbus_configure(&Serial, 9600, SERIAL_8N1, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  // modbus_update_comms(baud, byteFormat, id) is not needed but allows for easy update of the
  // port variables and slave id dynamically in any function.
  modbus_update_comms(9600, SERIAL_8N1, 4);
  pinMode(LED, OUTPUT);
  sensor_gaz_we.requestTemperatures();
  sensor_gaz_wy.requestTemperatures();
  sensor_ciecz_we.requestTemperatures();
  sensor_ciecz_wy.requestTemperatures();
  float temp_gaz_we = sensor_gaz_we.getTempCByIndex(0);
  float temp_gaz_wy = sensor_gaz_wy.getTempCByIndex(0);
  float temp_ciecz_we = sensor_ciecz_we.getTempCByIndex(0);
  float temp_ciecz_wy = sensor_ciecz_wy.getTempCByIndex(0);
      modbus_update();
        holdingRegs[1] = temp_gaz_we;
        holdingRegs[2] = temp_gaz_wy;
        holdingRegs[3] = temp_ciecz_we;
        holdingRegs[4] = temp_ciecz_wy;
Next bus or next device on the bus?
I have doubts about this. On 9600 baud you get about 10 bytes transferred in one scan period. The necessary inter-message pauses sum up to at least 7 bytes transfer time. It's impossible to send a request and an answer in 3 bytes.
You failed to provide a link to your Fatek device but a quick search let me assume it's a Ethernet-serial-converter (actually it's a server providing network to serial conversion). Don't expect such a device to being able to fulfill the timing requirements of Modbus. It's even very difficult to reach them using an USB device, it's almost impossible to do that with such a network converter.
I use the bus to connect one sensor without addressing, i.e. four bus , four sensors (this way I avoid the problem with sensor addresses in case of failure) I can't do otherwise, if there is an easier way, please guide me. I use for communication Moduł komunikacyjny Fatek FBs-CM25C - Sterowniki PLC Fatek - Automatyka-sklep.eu .
Using Modbus you need addressing anyway and if you don't do the addressing correctly it won't work anyway.
If you use multiple buses on the PC I guess you start the application (that mbus.exe which you still didn't a link for) multiple time, once for every bus. The multitasking system of your operating will send the characters out the serial line in any order the timing might vary a lot. Don't expect a Modbus system to work in such an environment.
You might have a chance to get it to work if you use only one bus but Modbus on a PC won't be reliable at higher message frequencies. I had the same problem and I moved the Modbus timing to an Arduino once I realized that.
