RS485 monitor to energise relay
Hi guys.
Im new to arduino
What i need to build using and arduino nano and an rs485 module is the following.
When the RS485 data FF01000700575F is received by the nano it will pause for 1 second then energise an output with relay for 5 seconds then switch off and back to its receiving state.
Does anyone have something like this already constructed and coded that they can help me get started with.
Many thanks
Bruton.
I doubt that this was already coded as it’s a quite exotic specification. The sketch needed to fulfill this specification is about 15 lines so I’m quite sure you’ll get that done yourself if you actually start getting involved with Arduino. A proper hardware setup for it is a bit more work but no witchery.
Don’t expect us to do your job. I suggest you start experimenting with easy Arduino setups to get familiar with the basic concepts. Once you have done basic serial interfacing and switch some LEDs you might setup your hardware for the described purpose. Implement a corresponding sketch and if you get into trouble with it, post all the information you have about the hardware, it’s wiring and the used code here and we will try to help you.
Ive been trying some code but the output is high all the time even when not receiving RS485 data. Is there something im missing. Here is the code.
 // Serial1.begin(2400);//Uncomment for Arduino Lenardo
  Serial.begin(2400);
  //while(!Serial1);//Uncomment for Arduino Lenardo
  pinMode(13, OUTPUT);//Led Connected
  pinMode(8, OUTPUT);//DE/RE Controling pin of RS-485
  pinMode(9, OUTPUT);//Detection of RS485 code
  char getdata='c';
  digitalWrite(13,LOW);//Led OFF
  digitalWrite(8,LOW);//DE/RE=LOW Receive Enabled
  digitalWrite(9,LOW);//RS485 detection relay LOW
   if(Serial.available()){
    getdata=Serial.read();
   if(getdata='FF01000700575F'){
      digitalWrite(8,HIGH);//RS485 detection LED HIGH
      digitalWrite(9,HIGH);//RS485 detection relay HIGH
delay(2000);
digitalWrite(13,HIGH);//Led ON
delay(2000);
A char variable can only hold one character, while your expected command 'FF01000700575F' consists of 14 characters, eventually hex encoding of 7 bytes. You have to declare an array of char, put the received characters into it, and compare it to the expected string.
Are you sure that you don't want to receive IR control codes?
It also does the same with 1 character using this code.
  Serial.begin(2400);
  char getdata='c';
   if(getdata='F'){
delay(2000);
delay(2000);
DrDiettrich:
The reason for this project is to take RS485 data from the back of a cctv camera. I am using preset function to energise a pump relay so when you call the preset the camera moves to a position energises a water pump to spray onto the front glass then the wiper motor runs to wipe the glass.
The RS485 data sent when calling the wash position sends FF01000700575F.
Read about hex number representation and input parsing in the Reference.
Something you should understand is that serial is magnitudes slower than Arduino. Your code should treat it like package deliveries coming to the door a few times a day, not like as soon as the first char arrives the rest are right there too.
2400 baud =is= 240 chars per second. That's 66,666 cycles in between arrivals that processing can be done. That is a lot of computing when it's not wasted.
I see you have delays to slow the Arduino down and just fyi, that's a very poor solution where better ways are taught.
You may not have to buffer anything to find a string in serial data. You only need a copy of what to match, a counter to store how many chars have matched and code that can move the match process along.
FF01000700575F
Could that be embedded in other hex? FFFF01000700575F33 or will the string to match start after a delimiter like a space, comma or new line?
Is there any sort of structure associated with that message? For example:
FF - msg header
01 - command low byte
00 - command high byte
07 - total number of bytes in msg
00 - data 2
57 - data 2
5F - checksum or CRC...?
   if(getdata='F'){
That’s an assignment and not a comparison. The equality comparison operator is ‘==’.
Blackfin:
FF - msg header
00 - data 2
57 - data 2
Yes Blackfin you are correct. This is the Pelco protocol im working with.
GoForSmoke:
FF01000700575F
Could that be embedded in other hex? FF*FF01000700575F*33 or will the string to match start after a delimiter like a space, comma or new line?
Its Pelco D im working with and I already have an off the shelf PTZ system that runs at 2400 so this dictates the baud rate for all connected devices.
pylon:
   if(getdata='F'){
Thanks
This helped keep the output low at startup.
bruton:
Then you know that the text will arrive very slowly in terms of the speed your code runs.
Quote from: Blackfin on Jan 22, 2019, 09:25 am
FF - msg header
00 - data 2
57 - data 2
I would build a state machine that recognizes the rather simple protocol and acts upon the desired message.
state
0 -- waiting for a message up to the 1st 'F'
1 -- get the header
2 -- get the command bytes
3 -- ..................
99 -- error, no match
No need to buffer then after all the bytes are in find out if it's good. With a match routine or state routine you can know if it's good on or before the last char arrives.
OP, check your PMs.
  1. Gammon Forum : Electronics : Microprocessors : How to do multiple things at once ... like cook bacon and eggs ← tasking Arduino 1-2-3
  2. Gammon Forum : Electronics : Microprocessors : How to process incoming serial data without blocking ← techniques howto
At the 1st link is background to making multiple things happen at once that starts with an example of cooking breakfast.
The 2nd link is techniques to work with serial without making other tasks wait. The 2nd technique is the State Machine that is a way to break action over time down into steps, a value in a variable controls which step runs “next time”, the machine runs over and over as void loop() goes round and round - the big wheel [nobbs]loop() { }[/nobbs] drives the little wheel tasks inside; always think of void loop() code as processes advancing over time, you can write code to deal with the real world.
These little chips crank along at amazing speed with no OS to slow then down. They can react to events very quickly.
Make your process to move along over many executions of loop() and keep the steps short so everything runs steps at 10KHz or a few times faster. My old demos with 4 or 5 small things at once ran loop() at >67KHz according to the loop counter task. When you check to see if 20 ms is up 67 times a ms, it’s not going to be very late in catching the ticks of the millis clock.
This is an approach, an angle on event-driven processing without an over-riding OS.
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
What RS485 module are you using, can you post a link to specs/data please?
Thanks… Tom… :slight_smile:
im back on this project but once again getting nowhere. I have never had any success with a max485 board with any arduino.
Does anyone think these boards are useless?
Not only do i not receive pelco but i dont receive any garbage data either
See post #16.
Can you post your code for the max485 project?
Thanks.. Tom.. :slight_smile:
All im after is a basic sketch to show the received pelco data from rs485. Ive trauled the internet and been sent code to try but absolutely nothing has worked. Either the code doesnt compile or it just does nothing.
Like i say if i can get it to receive basic data i can prgress from there.
Im using a rs485 to ttl cheap pcb. Looks like the most common for sale on the internet
