RS485 Sensor with Arduino
Hello everyone,
I am trying to connect my Soil Moisture sensor (Truebner SMT100) to my Arduino and get the readings but I keep receiving a question mark (?) on the serial monitor.
Could someone tell me what I am doing wrong so I could fix it myself ?
I appreciate everybody’s time to read this and I am looking forward to your replies.
#include "Arduino.h"
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
// SD Card shield
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10; // Uno shield
String dataStringnames =""; // holds the names of the data to be written to the SD card
String dataString =""; // holds the data to be written to the SD card
#include <SoftwareSerial.h>
// pins talking to RS485 device
#define RS485rx     2 // RS485 Receive pin
#define RS485Tx     3 // RS485 Transmit pin
#define RS485inout   4 // RS485 Transmit or Receive status
#define RS485Transmit HIGH
#define RS485Receive  LOW
#define ledPin      13
#define baudRate    9600
#define serialdelay  500
// Define the RS485 object
SoftwareSerial mySerial(RS485rx, RS485Tx);
String AddValue;
String SMValue;
String TemValue;
String PermValue;
char Add[] = "GetAddress!";
char SM[] = "GetWaterContent!FFFFFF";
char Tem[] = "GetTemperature!FFFFFF";
char Perm[] = "GetPermittivity!FFFFFF";
int rtc_year = 0;
int rtc_month = 0;
int rtc_day = 0;
int rtc_hour = 0;
int rtc_min = 0;
int rtc_sec = 0;
// SETUP         SETUP         SETUP         SETUP         SETUP
  rtc.begin();
  SD.begin(chipSelect);
  // Set modes for pins
  pinMode(ledPin, OUTPUT);
  pinMode(RS485inout, OUTPUT);
  // Ensure the on-board LED is off
  digitalWrite(ledPin, LOW);
  // Set RS485 device to read initially
  digitalWrite(RS485inout, RS485Receive);
  mySerial.begin(baudRate);
  dataStringnames =  String("SM") + ";" + String("Temp") + ";"+ String("Perm") + ";"
                                     + String("year")+ ";" + String("month")+ ";" + String("day")+ ";"
                                     + String("hour")+ ";" + String("min")+ ";" + String("sec");
  File dataFile = SD.open("DATALOG.txt", FILE_WRITE);
    if (dataFile) {
    dataFile.println(dataStringnames);
    dataFile.close();
    // print to the serial port too:
    //Serial.println("SD working");
    Serial.println(dataStringnames);
  // if the file isn't open, pop up an error:
  else            {
    Serial.println("error opening DATALOG.txt");
// LOOP     LOOP     LOOP     LOOP     LOOP     LOOP     LOOP
    // RTC
    DateTime now = rtc.now();
    rtc_year = now.year();
    rtc_month = now.month();
    rtc_day = now.day();
    rtc_hour = now.hour();
    rtc_min =  now.minute();
    rtc_sec =  now.second();
//    //////////////////// Sensor Address
    Serial.print("Sending:");
    Serial.println(Add);
//    // Set the RS485 to transmit mode and send the value
    digitalWrite(RS485inout, RS485Transmit);
    mySerial.println(Add);
    mySerial.flush();//Wait for everything to be transmitted, before disabling transmitter.
//    // Switch RS485 to receive mode
    delay(serialdelay);
//    // After each characters are sent look for a received answer
    if (mySerial.available())
      AddValue = mySerial.readStringUntil('\n');
//      // Display it on the Serial Monitor as a char (not an integer value)
      Serial.print("                 Got back:");
      Serial.println(AddValue);
    else              {
    Serial.println("no response from sensor");
 //////////////////// Soil Moisture
    Serial.println(SM);
    mySerial.println(SM);
    delay(serialdelay);
      SMValue = mySerial.readStringUntil('\n');
      Serial.print("                 Got back:"); Serial.println(SMValue);
    else        {
//////////////////// Temperature
    //Serial.print("Sending:");Serial.println(Tem);
    mySerial.println(Tem);
    delay(serialdelay);
      TemValue = mySerial.readStringUntil('\n');
      Serial.print("                 Got back:"); Serial.println(AddValue);
       else {
//////////////////// Permitivitty
    Serial.println(Perm);
    mySerial.println(Perm);
    delay(serialdelay);
      PermValue = mySerial.readStringUntil('\n');
    else {
    dataString = String(SMValue)+ ";"+ String(TemValue) + ";" + String(PermValue)+ ";"
                                     + String(rtc_year)+ ";" + String(rtc_month)+ ";" + String(rtc_day)+ ";"
                                     + String(rtc_hour)+ ";" + String(rtc_min)+ ";" + String(rtc_sec);
    if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    Serial.println(dataString);
    Serial.println("");
    dataString = -9999;
 else {
    flushReceive();
    Serial.println("new cycle ----------------------------------------------------");
    delay(9000);
void flushReceive()
while(Serial.available())
  Serial.read();
while(mySerial.available())
  mySerial.read();
Is the baud rate (9600) correct for that sensor? Which protocol variant do you own? Where is the link to the devices manual?
I have some sample code for SMT100 on my website http://www.gardenergranny.de/bludit/smt100-rs485-with-arduino Could you give it a try?
Please check also the application note on the manufacturer website: http://www.truebner.de/sites/default/files/AN005.pdf
