RS485 Simple Integer transfer
Could some kind soul please help me modify the attached sketch so as to enable me to transfer
integers (-32,768 to 32,767) between 2 Arduino Uno ( and also Mega).
I am using the attached sketch of Ralph Bacon because it was the only simple one I could find that actually works, but I cannot modify it to transmit integers.
My knowledge of coding is very very very basic so little words would help .
Thanks in advance
TRANSMIT
#include "Arduino.h"
// Library to allow a Serial port on arbitrary pins
#include <SoftwareSerial.h>
// These are the pins we'll be talking to the RS485 device on
#define RS485rx		6 // RS485 Receive pin
#define RS485Tx		7 // RS485 Transmit pin
#define RS485inout	5 // RS485 Transmit or Receive status
#define RS485Transmit	HIGH
#define RS485Receive	LOW
#define ledPin			13
#define baudRate		9600
// Define the RS485 object
SoftwareSerial RS485(RS485rx, RS485Tx);
// The data bytes we're sending or receiving
byte rxValue;
byte txValue;
// SETUP         SETUP         SETUP         SETUP         SETUP
void setup() /****** SETUP: RUNS ONCE ******/
	// Debugging window
	// Set modes for pins
	pinMode(ledPin, OUTPUT);
	pinMode(RS485inout, OUTPUT);
	// Ensure the on-board LED is off
	digitalWrite(ledPin, HIGH);
	// Set RS485 device to read initially
	digitalWrite(RS485inout, RS485Receive);
	// Set the baud rate. The longer the wire the slower you should
	// set the transmission rate. Anything here:
	// 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 28800, 31250,
	// 38400, 57600, and 115200
	// MUST BE THE SAME AS THE SENDER UNIT!
	RS485.begin(baudRate);
// LOOP     LOOP     LOOP     LOOP     LOOP     LOOP     LOOP
	static String teststring = "12345"; // Serial Communication is easy!";
	// Continually send the test string with a pause at the end
	for (unsigned int cnt = 0; cnt < teststring.length(); cnt++) {
		// Get the next character to send
		txValue = teststring[cnt];
		Serial.print("Sending:");Serial.println(char(txValue));
		// Set the RS485 to transmit mode and send the value
		digitalWrite(RS485inout, RS485Transmit);
		RS485.write(txValue);
		// small delay to allow transmission to complete
		delay(1);
		// Switch RS485 to receive mode
delay(100);
		// After each character is sent look for a received answer
		if (RS485.available())
			// LED flicker
			// Read the incoming byte
			rxValue = RS485.read();
			// Display it on the Serial Monitor as a char (not an integer value)
			Serial.print("                 Got back:");	Serial.println(char(rxValue));
			// Turn off LED
			digitalWrite(ledPin, LOW);  // Show activity
		// Debugging delay so we can follow activity
		delay(100);
	// Entire string sent, longer delay between loops
	//while (!Serial.available());
	//while (Serial.available()){Serial.read();}
	delay(2500);
RECEIVE
[code]
#define ledPin			13
byte rxValue;
byte txValue;
  // Debugging window
  // Is there something on the serial pin?
    txValue = RS485.read();
    Serial.print("Received:");Serial.println(char(txValue));
    // Turn on the on-board LED pin to show activity
    // Set the direction pin to xmit (HIGH)
    // This delay is REQUIRED for things to settle before transmission
    delay(10);
    // Send back a modified value
    // Wait for the transmission to complete.
    // This delay is dependent on the baud rate. To calculate:
    // delay = (baud rate / 10) * 2
    int bufferDelay = (baudRate / 10) * 2 + 100;
    delayMicroseconds(bufferDelay);
    // Set the RS485 back to receive
    // Turn off built in LED pin
[/code]
Int variables are 2 bytes on the Uno and Mega so in place of the for() loop iterating over all the elements in a String, you need to send the high byte and then the low byte
int myVal = -100;
txValue = myVal >> 8;  // high byte
// send it out
txValue = myVal & 0xFF; // low byte
// send it out
Thanks for your reply.
How do I convert it back to an integer on the Receiver side?
Farticus:
int Result = (RxBuff[0] << 8) + RxBuff[1];
Think I may have mucked it up somewhere.
I am getting a print out on the Sender Serial monitor but nothing on the receiver side.
I cannot get the Receiver sketch to compile
ERROR "RxValueBuff not declared in this scope"
#define ledPin			13
int myVal = 25320;
byte rxValue;
byte txValue;
	// Debugging window
// send it out
// send it out
    Serial.print("myVal is....");Serial.print(myVal);Serial.print("  txValue is ....");Serial.println(txValue);
   delay(2000);
    myVal ++;
RECEIVER
[code]
#define ledPin			13
byte rxValue;
byte txValue;
  // Debugging window
  Serial.println (" Inside Void Loop");
  Serial.println("Inside IFRS485Avail Loop");
    int Result = (RxValueBuff[0] << 8) + RxValueBuff[1]; // [i]ERROR RxValueBuff not declared in this scope"[/i]
   Serial.println( rxValue);
    delay (2000);
[/code]
A very simple failure: you did not define the buffer named "RxValueBuff" - so the compiler can not find it.
Do you really use RS485 (instead of normal RS232) ?
Have amended Receiver sketch as you suggested but now get a compiler error
"int Result = (RxBuff[0] << 8) + RxValueBuff[1]; // ERROR expected identifier before numeric constant"
Have attached error message
error.txt (1.55 KB)
RxBuff and RxValueBuff?
Sorry but I dont get what you mean.
Changing code to this:
gives me a compiling error I originally had:
ERROR "expected identifier before numeric constant"
I realise that from your perspective my error is most basic but I just dont get it I am sorry.
Try this on your receiver:
//Ref: ..Documents\Arduino\sketch_nov09b.ino
#define BUFF_SIZE       10
#define ledPin          13
byte
    rxIdx,
    rxBuff[BUFF_SIZE];
    // Debugging window
    pinMode( ledPin, OUTPUT );
    pinMode( RS485inout, OUTPUT );
    digitalWrite( RS485inout, RS485Receive );   // Set RS485 device to read initially
    rxIdx = 0;
}//setup
    if( RS485.available() )
        do
            rxBuff[rxIdx] = RS485.read();
            rxIdx++;
            if( rxIdx == 2 )
                int Result = (rxBuff[0] << 8) + rxBuff[1];
                Serial.print( "Received: " ); Serial.println( Result );
                rxIdx = 0;
            }//if
        }while( RS485.available() );
    }//if
}//loop
Results are
Sender myVal Sender txVal Receiver Result
12 12 3084
123 123 31611
1234 210 -11566
12345 57 1469
Please show your transmitter code that was used in this test.
#define ledPin			13
int myVal = 132;
byte rxValue;
byte txValue;
	// Debugging window
// send it out
// send it out
   delay(2000);
    myVal ++;
So try this loop() instead:
    Serial.print("  High byte of myVal is ");
    Serial.print( myVal >> 8 );
    Serial.print("  Low byte of myVal is ");
    Serial.println( myVal & 0xff );
    delay(2000);
    myVal++;
}//loop
Because there are no framing characters to synchronize the transmitter and receiver, turn on the receiver first, then the transmitter.
Thank You,,,,,, Thank You,,,,,,,,,,Thank You.
Works perfectly :slight_smile: :slight_smile: :slight_smile:
I would like to try to understand the workings, is there any simple explanation
for a "newbie" such as my self or anywhere I could read up on it in "Dummy Speak".
Once again Thanks
Have tried to implement these sketches on Arduino Mega boards.
Uno TX Uno RX No Problems over 40 M wires.
MegaTX Uno Rx No probs.
Mega TX Mega Rx No response from RX
Tried a common ground made no difference
RS 485's powered from independent 5V power source.
Use same pins( 5,6 & 7).
Have tried independent 5V to Mega RX board.
Have tried 3 different Mega boards. All will transmit but none will "receive".
Any suggestions
