we trying to connect two arduinos (one of them is an Arduino one and other one is Arduino leonardo).
we are using the software version 1.6.5 and also we have just downloaded SoftwareSerial.h
it came with this examples:
Server:
/* YourDuino SoftwareSerialExample1
- Connect to another Arduino running "YD_SoftwareSerialExampleRS485_1Remote"
- Connect this unit Pins 10, 11, Gnd
- Pin 3 used for RS485 direction control
- To other unit Pins 11,10, Gnd (Cross over)
- Open Serial Monitor, type in top window.
- Should see same characters echoed back from remote Arduino
Questions: terry@yourduino.com
/*-----( Import needed libraries )-----*/
#include <SoftwareSerial.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define SSerialRX 10 //Serial Receive pin
#define SSerialTX 11 //Serial Transmit pin
#define SSerialTxControl 12 //RS485 Direction control
#define RS485Transmit HIGH
#define RS485Receive LOW
#define Pin13LED 13
/*-----( Declare objects )-----*/
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
/*-----( Declare Variables )-----*/
int byteReceived;
int byteSend;
void setup() /****** SETUP: RUNS ONCE ******/
// Start the built-in serial port, probably to Serial Monitor
Serial.println("YourDuino.com SoftwareSerial remote loop example");
Serial.println("Use Serial Monitor, type in upper window, ENTER");
pinMode(Pin13LED, OUTPUT);
pinMode(SSerialTxControl, OUTPUT);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
// Start the software serial port, to another device
RS485Serial.begin(4800); // set the data rate
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
digitalWrite(Pin13LED, HIGH); // Show activity
if (Serial.available())
byteReceived = Serial.read();
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
RS485Serial.write(byteReceived); // Send byte to Remote Arduino
digitalWrite(Pin13LED, LOW); // Show activity
delay(10);
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit
if (RS485Serial.available()) //Look for data from other Arduino
byteReceived = RS485Serial.read(); // Read received byte
Serial.println(byteReceived); // Show on Serial Monitor
delay(10);
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//NONE
//*********( THE END )***********
Slave
/* YourDuino SoftwareSerialExample1Remote
- Used with YD_SoftwareSerialExampleRS485_1 on another Arduino
- Remote: Receive data, loop it back...
- Pin 13 LED blinks when data is received
#define SSerialTxControl 3 //RS485 Direction control
#define Pin13LED 13
int byteReceived;
int byteSend;
Serial.println("SerialRemote"); // Can be ignored
//Copy input data to output
byteSend = RS485Serial.read(); // Read the byte
//Serial.println(byteSend)
delay(10);
RS485Serial.write(byteSend); // Send the byte back
delay(10);
// delay(100);
}// End If RS485SerialAvailable
//NONE
we have the hardware correctly connected, but when we send some characters from the Serial monitor , other character are returned, i dont know what are we doing wrong our hardware is this one:
http://johanneskinzig.de/_Media/arduinors485_schaltplan_med_hr.jpeg
Please Help or im gonna kill my self.
