RS485 - Transmit text via struct (Nick Gammon's code)
Hello.
I'm use Non-blocking code from Nick Gammon (Gammon Forum : Electronics : Microprocessors : RS485 communications)
Master:
#include <RS485_non_blocking.h>
#include <SoftwareSerial.h>
#define RS485_RX_PIN          6
#define RS485_TX_PIN          5
SoftwareSerial rs485(RS485_RX_PIN, RS485_TX_PIN);  // receive pin, transmit pin
struct          // packet data structure
  byte thisDeviceID;
  byte destinationID;
  int  value;
  String msg;
} data;
size_t fWrite(const byte what)
  return rs485.write(what);
RS485 network(NULL, NULL, fWrite, 0);
  rs485.begin(9600); // software serial for talking to other devices
  network.begin(); // initialize the RS485 library
}  // end of setup
  //const byte msg[] = "Hello world";  // works fine, but why "byte"?
  //network.sendMsg(msg, sizeof (msg));
  memset(&data, 0, sizeof(data));
  data.thisDeviceID = 3;
  data.destinationID = 0;
  data.value = 8;
  data.msg = "Test point";
  network.sendMsg((byte *) &data, sizeof data);
  delay (1000);
}  // end of loop
Slave:
struct          // packet data sctructure
  byte thisDeviceID;
  byte destinationID;
  int  value;
  String msg;
} data;
int fAvailable()
  return rs485.available();
int fRead()
  return rs485.read();
RS485 network(fRead, fAvailable, NULL, 20);
}  // end of setup
  if (network.update())
    //    Serial.write(network.getData(), network.getLength());  works fine with byte msg[] = "Hello world"
    //  Serial.println();
    memset(&data, 0, sizeof (data));
    int len = network.getLength();
    if (len > sizeof (data)) len = sizeof (data);
    memcpy(&data, network.getData(), len);
    Serial.println(data.thisDeviceID);
    Serial.println(data.destinationID);
    Serial.println(data.value);
    Serial.println(data.msg);
}  // end of loop
Result:
3
0
8
<< here empty line instead text
Where is mistake?
String saves the actual text data on the heap, it's dynamically allocated.
data.msg is a String object, somewhere in there, it contains a pointer to a an array of chars in the heap.
By sending data.msg, you only send this pointer, not the actual data.
Pieter
