hi, I'm working on a project that has a linux server running python communicating with the Yun over udp and I wanted to encrypt the packets using RSA.
I don't have any problems with the linux server using pycrypto libraries but the problem lies with the linino's lacking python-crypto library. Is there any way to install the latest pycrypto on the Yun? I tried installing using pip but it keeps returning this error:
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-build-_yqGLV/pycrypto/setup.py", line 456, in <module>
core.setup(**kw)
File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/usr/lib/python2.7/site-packages/setuptools/command/install.py", line 53, in run
return _install.run(self)
File "/usr/lib/python2.7/distutils/command/install.py", line 563, in run
self.run_command('build')
File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python2.7/distutils/command/build.py", line 127, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-build-_yqGLV/pycrypto/setup.py", line 251, in run
cmd_obj.run()
File "/tmp/pip-build-_yqGLV/pycrypto/setup.py", line 278, in run
raise RuntimeError("autoconf error")
RuntimeError: autoconf error
Command "/usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-_yqGLV/pycrypto/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-m1vtUd-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-_yqGLV/pycrypto
because the linino doesn't have a C compiler. is there any way to precompile from another machine?
I really need some functions like importKey() from the latest version of pycrypto.
TIA
