Hello,
I have hc-05 as master and hc-06 as slave.
When i try to pair them both, i get RSSI values like this:
FF43
FF03
FFC1
FF34
What does it mean? I need the values in dBM?
I appreciate your helps.
Hello,
FF43
FF03
FFC1
FF34
What does it mean?
Looks like signed sixteen bit numbers, to me, printed as unsigned hex.
The numbers really dont mean anything, other than a relative value which will go up or down based on the signal strength.
But RSSI is really a useless value for most things, as there are too many variables which can affect it.
You wont get dbm values from any radios that I know of, unless you have a commercial EMI meter.
mauried:
I got what you mean but I need RSSI values in dBm, is there anyway to obtain that value? My setup contains HC-05 and HC-06 ? I just need the signal strength in dBm. I am now doing it in AT mode by AT+INQ so i have those values in hexadecimal.
AWOL:
What about converting it into decimal and apply '10log(decimal value)' ? Does this give me dBm ?
dBm is a measure of power , referanced to 1 mw , where 0 dbm = 1 mw.
RSSI is just a voltage generated by the AGC gain control loop in a receiver, and thats all it is .
It has no meaning other than a relative value that indicates whether the signal strength is going up or down, but it doesnt tell you what the signal strength is .
I need some scale or something to tell me signal strength, anyone can help ?
