RSSI Wifi and bluetooth from Arduino to Smartphone
Hello :slight_smile:
I'm beginner and I need your help.
I want to make a project on Arduino Uno that to counts the signal Distance the Smartphone and detects.
What equipment and information networks for programming that I can study sources?
Distance sensor?
I think you need a GPS on the Arduino to determine the Arduino's position and a program on the Smartphone to send its GPS position to the Arduino. Then compare the two.
...R
Sorry my mistake. I change title.
I want to create with Arduino to Received signal strength indication wifi and bluetooth my Smartphone.
How to make that? Also,What equipment and information networks for programming that I can study sources?
Use the search box in the upper right of this page to search for “rssi” to see post similar to yours.
I believe RSSI is a poor indicator of distance - which is why I suggested GPS.
...R
For example, as you see in the program WifiChannelMonitor website Monitor APs and wifi clients on selected channel (Monitor Mode) - Tool for Windows see through this a device that tells the RSSI. Example https://www.pozyx.io/
How can I do with Arduino Uno? Is there some equipment for Arduino Wifi to make self?
I am interested only RSSI.
