rtc 3231 is not cooperating assistance pleaaase
hello all i am simply trying to get my rtc going and am not having any luck at first i thought it was the module so i bought two more and am still not getting any results...
i have ground and vcc (3.3) sda to a4 and scl to a5( arduino uno) i used the library located here DS3231 - Rinky-Dink Electronics
and i am not getting anything displayed to my serial monitor. i also used this code with no results
#include <Wire.h>
#define DS3231_I2C_ADDRESS 104
// SCL - pin A5
// SDA - pin A4
// To set the clock, run the sketch and use the serial monitor.
// Enter T1124154091014; the code will read this and set the clock. See the code for full details.
byte seconds, minutes, hours, day, date, month, year;
char weekDay[4];
byte tMSB, tLSB;
float temp3231;
  Wire.begin();
  watchConsole();
  get3231Date();
  Serial.print(weekDay); Serial.print(", "); Serial.print(date, DEC); Serial.print("/"); Serial.print(month, DEC); Serial.print("/"); Serial.print(year, DEC); Serial.print(" - ");
  Serial.print(hours, DEC); Serial.print(":"); Serial.print(minutes, DEC); Serial.print(":"); Serial.print(seconds, DEC);
  Serial.print(" - Temp: "); Serial.println(get3231Temp());
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
void watchConsole()
  if (Serial.available()) {      // Look for char in serial queue and process if found
    if (Serial.read() == 84) {      //If command = "T" Set Date
      set3231Date();
      get3231Date();
      Serial.println(" ");
void set3231Date()
//T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year)
//T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99)
//Example: 02-Feb-09 @ 19:57:11 for the 3rd day of the week -> T1157193020209
// T1124154091014
  seconds = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
  minutes = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  hours   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  day     = (byte) (Serial.read() - 48);
  date    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  month   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  year    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  Wire.beginTransmission(DS3231_I2C_ADDRESS);
  Wire.write(0x00);
  Wire.write(decToBcd(seconds));
  Wire.write(decToBcd(minutes));
  Wire.write(decToBcd(hours));
  Wire.write(decToBcd(day));
  Wire.write(decToBcd(date));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.endTransmission();
void get3231Date()
  // send request to receive data starting at register 0
  Wire.beginTransmission(DS3231_I2C_ADDRESS); // 104 is DS3231 device address
  Wire.write(0x00); // start at register 0
  Wire.requestFrom(DS3231_I2C_ADDRESS, 7); // request seven bytes
  if(Wire.available()) {
    seconds = Wire.read(); // get seconds
    minutes = Wire.read(); // get minutes
    hours   = Wire.read();   // get hours
    day     = Wire.read();
    date    = Wire.read();
    month   = Wire.read(); //temp month
    year    = Wire.read();
    seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111)); // convert BCD to decimal
    minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111)); // convert BCD to decimal
    hours   = (((hours & B00110000)>>4)*10 + (hours & B00001111)); // convert BCD to decimal (assume 24 hour mode)
    day     = (day & B00000111); // 1-7
    date    = (((date & B00110000)>>4)*10 + (date & B00001111)); // 1-31
    month   = (((month & B00010000)>>4)*10 + (month & B00001111)); //msb7 is century overflow
    year    = (((year & B11110000)>>4)*10 + (year & B00001111));
  else {
    //oh noes, no data!
  switch (day) {
    case 1:
      strcpy(weekDay, "Sun");
    case 2:
      strcpy(weekDay, "Mon");
    case 3:
      strcpy(weekDay, "Tue");
    case 4:
      strcpy(weekDay, "Wed");
    case 5:
      strcpy(weekDay, "Thu");
    case 6:
      strcpy(weekDay, "Fri");
    case 7:
      strcpy(weekDay, "Sat");
float get3231Temp()
  //temp registers (11h-12h) get updated automatically every 64s
  Wire.write(0x11);
  Wire.requestFrom(DS3231_I2C_ADDRESS, 2);
    tMSB = Wire.read(); //2's complement int portion
    tLSB = Wire.read(); //fraction portion
    temp3231 = (tMSB & B01111111); //do 2's math on Tmsb
    temp3231 += ( (tLSB >> 6) * 0.25 ); //only care about bits 7 & 8
  else {
    //oh noes, no data!
  return temp3231;
(copy and pasted (T1124154091014;) into the serial monitor both with and without ; and have still gotten nothing back.
any help is appreciated thank you!!
Rather than using the library provided by RinkyDinky electronics, you should use the more primordial method of implementing the DS3231. From what I know, using the library provided by that website renders it difficult for you to use the I2C protocol and will create further problems. Instead, try this method.
Make the following connections to the DS3231 :-
  1. SDA Pin A4
  2. SCL Pin A5
  3. GND GND
  4. VCC 5V
    Upload the following code :-
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
  return( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return( (val/16*10) + (val%16) );
  Wire.begin();
  // set the initial time here:
  // DS3231 seconds, minutes, hours, day, date, month, year
  // setDS3231time(30,42,21,4,26,11,14);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
  // sets time and date data to DS3231
  Wire.write(0); // set next input to start at the seconds register
  Wire.write(decToBcd(second)); // set seconds
  Wire.write(decToBcd(minute)); // set minutes
  Wire.write(decToBcd(hour)); // set hours
  Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
  Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
  Wire.write(decToBcd(month)); // set month
  Wire.write(decToBcd(year)); // set year (0 to 99)
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.write(0); // set DS3231 register pointer to 00h
  // request seven bytes of data from DS3231 starting from register 00h
  *second = bcdToDec(Wire.read() & 0x7f);
  *minute = bcdToDec(Wire.read());
  *hour = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month = bcdToDec(Wire.read());
  *year = bcdToDec(Wire.read());
void displayTime()
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  // retrieve data from DS3231
  readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
  &year);
  // send it to the serial monitor
  Serial.print(hour, DEC);
  // convert the byte variable to a decimal number when displayed
  Serial.print(":");
  if (minute<10)
    Serial.print("0");
  Serial.print(minute, DEC);
  Serial.print(":");
  if (second<10)
    Serial.print("0");
  Serial.print(second, DEC);
  Serial.print(" ");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print("/");
  Serial.print(" Day of week: ");
  switch(dayOfWeek){
  case 1:
    Serial.println("Sunday");
  case 2:
    Serial.println("Monday");
  case 3:
    Serial.println("Tuesday");
  case 4:
    Serial.println("Wednesday");
  case 5:
    Serial.println("Thursday");
  case 6:
    Serial.println("Friday");
  case 7:
    Serial.println("Saturday");
  displayTime(); // display the real-time clock data on the Serial Monitor,
  delay(1000); // every second
ieatflys where is your code?
Have you tried the examples with the library?
Have you set the monitor baud rate to match the baud rate set in the code?
Tom.. :slight_smile:
adeelshams i just tried that code and uncommeted that line and then recomment after i run the code and pull up the cerial monitor and i still get nothing. i ave vcc to 3.3v as thats within the voltage range will it only work at 5? i have tried 5 in the past with no luck but can try again.
TomGeorge
woops i fixed the issue i believe with the code. i have tried many examples from a few libraries and i matched the baud with the code at 9600 baud.
thanks guys
up
ieatflys:
up
down.
For starters, the DS3231 will NOT work on 3.3V, so you need to use 5V.
Well disregard that, i wasn't awake there ...
To make sure that the I2C connection is working (and your pullups are connected correct) - run an I2C-scanner to see if it can detect the RTC.
// Per.
From the Maxim data sheet.
Supply Voltage
Min Typ Max
VCC 2.3 3.3 5.5 V
VBAT 2.3 3.0 5.5 V
The DS1307 is indeed a 5v device, but one of the advantages of the DS3231 is the 3.3v operation.
cattledog:
Sorry, my bad :smiley:
// Per.
