RTC alarm not working
I'm trying to set an alarm to update sensor readings at the top of each hour. After lots of trial and error I finally got the RTC to work on my Nano 33 IOT. The sensor readings and everything else is working fine, but the code just seems to skip the alarm. I put a counter in the alarmMatch subroutine to increment each time the alarm is tripped, but so far I haven't seen it work.
Here's the code I'm working with:
  Sketch generated by the Arduino IoT Cloud Thing "Weather V3"
  https://create.arduino.cc/cloud/things/710e1d97-e9ce-414d-893a-49f0166698b8
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  String barState;
  String rainAmount;
  float humidity;
  float maxTempF;
  float minTempF;
  float pressure;
  float pressure_HG;
  float rainAmt;
  float rainAmtInches;
  float rainVal;
  float tempC;
  float tempF;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
int alarmRun;
// Real Time Clock
    #include <RTCZero.h>
    //#include <WiFiNINA.h>
    //#include <WiFiUdp.h>
    const int GMT = -5; // Time zone constant - change as required for your location
    // Create object
    RTCZero rtc2;
/* Change these values to set the current initial time */
    const byte seconds = 0;
    const byte minutes = 50;
    const byte hours = 13;
/* Change these values to set the current initial date */
    const byte day = 9;
    const byte month = 3;
    const byte year = 22;
// BMP280
    #include <Wire.h>
    #include <SPI.h>
    #include <Adafruit_BMP280.h>
    Adafruit_BMP280 bmp; // use I2C interface
    float previousPressure;
    int displayPressure;
// DHT11
    #include <DHT.h>
    #define Type DHT11
    int sensePin=5;
    DHT HT(sensePin,Type);
// Rain Sensor
    int rainSense=A3;
    int rainPresence=4;
    int rainState;
// Tipping Bucket
    int tipPin=9;
    int tipSense;
    int tipCount;
    unsigned long button_time = 0;
    unsigned long last_button_time = 0;
// Defined in thingProperties.h
    initProperties();
// Connect to Arduino IoT Cloud
    ArduinoCloud.begin(ArduinoIoTPreferredConnection);
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
    delay(1500);
    The following function allows you to obtain more information
    related to the state of network and IoT Cloud connection and errors
    the higher number the more granular information you’ll get.
    The default is 0 (only errors).
    Maximum is 4
    setDebugMessageLevel(2);
    ArduinoCloud.printDebugInfo();
// Start Real Time Clock
// Initialize RTC
  rtc2.begin();
  // Set the time
  rtc2.setHours(hours-GMT);
  rtc2.setMinutes(minutes);
  rtc2.setSeconds(seconds);
  // Set the date
  rtc2.setDay(day);
  rtc2.setMonth(month);
  rtc2.setYear(year);
// Set alarm to update min, max and rain
    rtc2.setAlarmTime(00, 00, 00);
    rtc2.enableAlarm(rtc2.MATCH_MMSS);
    rtc2.attachInterrupt(alarmMatch);
// Start DHT
    HT.begin();
// Start BMP
    unsigned status;
    status = bmp.begin();
    while ( !Serial ) delay(100);   // wait for native usb
    Serial.println(F("BMP280 test"));
    bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                    Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                    Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                    Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                    Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
    if (!status)
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
                        "try a different address!"));
    Serial.print("SensorID was: 0x"); Serial.println(bmp.sensorID(),16);
    Serial.print("        ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
    Serial.print("   ID of 0x56-0x58 represents a BMP 280,\n");
    Serial.print("        ID of 0x60 represents a BME 280.\n");
    Serial.print("        ID of 0x61 represents a BME 680.\n");
    while (1) delay(10);
    pinMode(rainSense,INPUT);
    pinMode(tipPin,INPUT_PULLUP);
    digitalWrite(tipPin,HIGH);
    minTempF=70;
    attachInterrupt(digitalPinToInterrupt(tipPin), tipBucket_ISR, CHANGE);
    ArduinoCloud.update();
// Read Sensors
// Get temp and humidity
    humidity=HT.readHumidity();
    humidity=round(humidity);
    tempC=HT.readTemperature();
    tempF=HT.readTemperature(true);
    tempF=round(tempF);
    if (tempF>maxTempF)
      maxTempF=tempF;
    if (tempF<=minTempF)
    minTempF=tempF;
// Get Pressure
    pressure=((bmp.readPressure()/100)+43.33);
    displayPressure=round(pressure);
    pressure_HG=(pressure*.0295);
    //pressure_HG=round(pressure_HG);
    //displayPressure=int(pressure);
    if (pressure == previousPressure)
      barState="Steady";
    else if(pressure<previousPressure+5)
      barState="Falling";
    else if(pressure>previousPressure-5)
      barState="Rising";
    previousPressure=displayPressure;
// Get rain sense
    rainVal=analogRead(rainSense);
    rainState=digitalRead(rainPresence);
    if (rainState==HIGH)
      rainAmount="Dry";
    else if(rainState==LOW)
      rainAmount="Raining";
// Display sensor data on Serial Monitor
    Serial.print("Max Temp ");
    Serial.println(maxTempF);
        minTempF=tempF;
    Serial.print("Min Temp ");
    Serial.println(minTempF);
    Serial.print("Humidity: ");
    Serial.println(humidity);
    Serial.print("temp C ");
    Serial.println(tempC);
    Serial.print("temp F ");
    Serial.println(tempF);
    Serial.print("Previous Pressure ");
    Serial.println(previousPressure);
    Serial.print(F("Pressure = "));
    Serial.print(displayPressure);
    Serial.println(" hPa");
    Serial.print("Pressure inches HG ");
    Serial.println(pressure_HG);
    Serial.println(barState);
    Serial.print("Rain/Dry");
    Serial.println(rainAmount);
    Serial.print ("tipSense ");
    Serial.println(tipSense);
    Serial.print ("Tip Count = ");
    Serial.println (tipCount);
    rainAmt=tipCount*.2;
    rainAmtInches=(rainAmt*.0394);
    Serial.print("Rain Amount mm ");
    Serial.println(rainAmt);
    Serial.print("Rain Amount Inches ");
    Serial.println(rainAmtInches);
    Serial.println(alarmRun);
  Serial.println("Current Time ");
    // Print date...
  print2digits(rtc2.getDay());
  Serial.print("/");
  print2digits(rtc2.getMonth());
  Serial.print("/");
  print2digits(rtc2.getYear());
  Serial.print(" ");
  // ...and time
  print2digits(rtc2.getHours());
  Serial.print(":");
  print2digits(rtc2.getMinutes());
  Serial.print(":");
  print2digits(rtc2.getSeconds());
void print2digits(int number)
  if (number < 10) {
    Serial.print("0"); // print a 0 before if the number is < than 10
  Serial.print(number);
// Get tipping bucket ISR
void tipBucket_ISR()
    tipSense=digitalRead(tipPin);
    button_time=millis();
      if (button_time - last_button_time > 80)
        if (tipSense==0)
          tipCount=tipCount+1;
      last_button_time=button_time;
void alarmMatch()
    // reset Min Temp, Max Temp and Rain Amount
    minTempF=minTempF;
    maxTempF=maxTempF;
    rainAmt=0;
    tipCount=0;
    int alarmRun=alarmRun+1;
That function creates a new, local variable called alarmRun and initializes it to the global variable alarmRun + 1 and then throws the result away. The fact that they both have the same human readable name does not fool the compiler which knows they are two, completely different variables.
alarmRun++;
will increment your global variable.
