RTC and Motor Control
I want to create a device that uses a real time clock for scheduling and a servo motor to physically turn a dial through a series of positions throughout the day/night cycle. It seems that the Servo can be controlled directly from the arduino board, without any shields, using the Servo library but the real time clock does require a shield so my question is ....
Can I just add the RTC shield with stackable headers and then use two free header pins from the stackable headers to control the servo?
Thanks
Yes, you can. You can also stack 2 or more shields provided they use different I/O pins.
Thanks
