Hello forum!
Im trying to be able to change time on my RTC DS3231 with external buttons. I just want to be able to change hour and minutes.
So i found this code and got it up and running, all seems to work just fine.
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
Serial.begin(9600); // start the serial connection to the PC.
pinMode(2, INPUT); // set pin 2 as an input
digitalWrite(2, HIGH); // activate internal pullup resistor on pin 2
pinMode(3, INPUT); // set pin 3 as an input
digitalWrite(3, HIGH); // activate internal pullup resistor on pin 3
pinMode(4, INPUT); // set pin 4 as an input
digitalWrite(4, HIGH); // activate internal pullup resistor on pin 4
setSyncProvider(RTC.get); // the function to get the time from the RTC
setSyncInterval(60); // set the number of seconds between re-sync
if(timeStatus()!= timeSet)
Serial.println("Unable to sync with the RTC.");
Serial.println("RTC has been read.");
if (digitalRead(2) == LOW) { // Zero the minutes!
// setting the onboard time to 0 minutes.
setTime(hour(),0,second(),day(),month(), year());
RTC.set(now()); // sending the onboard time to the RTC.
Serial.println("Minutes Reset."); // send confirmation to the PC.
// *** had to adjust the adjustTime function in the Time library.
// Inside Time.cpp, the adjustTime method was replaced with:
// void adjustTime(long adjustment){
// setTime(sysTime + adjustment);
if (digitalRead(3) == LOW) { // add an hour!
adjustTime(3600); // adjust onboard time by +3600 seconds (1hr) ***
Serial.println("Added an hour."); // send confirmation to the PC.
if (digitalRead(4) == LOW) { // add a minute!
adjustTime(60); // adjust onboard time by +60 seconds (1min) ***
Serial.println("Added a minute."); // send confirmation to the PC.
// this section is for setting the rtc chip from the serial terminal.
if(Serial.available()){
time_t t = processSyncMessage();
if(t >0)
RTC.set(t); // set the RTC and the system time to the received value
setTime(t);
digitalClockDisplay(); // sends an update of the time to the PC.
delay(1000); // wait for a bit.
void digitalClockDisplay(){
// digital clock display of the time over serial
Serial.print(hour());
Serial.print(":");
printDigits(minute());
Serial.print(":");
printDigits(second());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
if(digits < 10)
Serial.print('0');
Serial.print(digits);
/* code to process time sync messages from the serial port */
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
time_t processSyncMessage() {
// return the time if a valid sync message is received on the serial port.
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
return pctime;
return 0;
Problem is that when i try to incorporate this to my main code im getting error compilings.
I’ll post my main code beneath this post, i suspect it has sometihng to do with <Time.h> and <DS1307RTC.h>
not working well together with the ones i’ve already put in my code which is <RTClib.h>
I’m afraid that i will have to change my main code to fit with <Time.h> and <DS1307RTC.h>
and that would be quite difficult, atleast for my knowlege level…
So to my question; is there a way to do this without the use of Time.h?
Any tips or hints would be much obliged
