RTC Clock with lcd
Heya there.
i got my Arduino Duemilanove and an LCD display, with a RTC module from Sparkun hooked up.
And got my clock working and displaying with this code:
// Connections:
// LCD pin 1 to Arduino GND
// LCD pin 2 to Arduino 5v
// LCD pin 3 (Contrast) to GND
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pin 16 to Arduino GND
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
//Tested with DS1307 Breakout from Sparkfun
//pin SDA to Arduino Analog pin 4
//pin SCL to Arduino Analog pin 5
//pin GND to Arduino GND
//pin VCC to Arduino 5v
#include <Wire.h>
#define DS1307_I2C_ADDRESS 0x68
#include <LiquidCrystal.h> // we need this library for the LCD commands
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13; // pin 13 will control the backlight
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.send(0);
Wire.send(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.send(decToBcd(minute));
Wire.send(decToBcd(hour));
Wire.send(decToBcd(dayOfWeek));
Wire.send(decToBcd(dayOfMonth));
Wire.send(decToBcd(month));
Wire.send(decToBcd(year));
Wire.send(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.send(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
*second = bcdToDec(Wire.receive() & 0x7f);
*minute = bcdToDec(Wire.receive());
*hour = bcdToDec(Wire.receive() & 0x3f); // Need to change this if 12 hour am/pm
*dayOfWeek = bcdToDec(Wire.receive());
*dayOfMonth = bcdToDec(Wire.receive());
*month = bcdToDec(Wire.receive());
*year = bcdToDec(Wire.receive());
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
Wire.begin();
// Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call.
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1;
dayOfMonth = 3;
month = 10;
year = 10;
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
lcd.begin(16, 2); // tells Arduino the LCD dimensions
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
lcd.clear(); // clear LCD screen
lcd.setCursor(0,0);
lcd.print(" ");
lcd.print(hour, DEC);
lcd.print(":");
if (minute<10)
lcd.print("0");
lcd.print(minute, DEC);
lcd.print(":");
if (second<10)
lcd.print("0");
lcd.print(second, DEC);
lcd.setCursor(0,1);
lcd.print(" ");
switch(dayOfWeek){
case 1:
lcd.print("Sun");
case 2:
lcd.print("Mon");
case 3:
lcd.print("Tue");
case 4:
lcd.print("Wed");
case 5:
lcd.print("Thu");
case 6:
lcd.print("Fri");
case 7:
lcd.print("Sat");
lcd.print(" ");
lcd.print(month, DEC);
lcd.print("/");
lcd.print(dayOfMonth, DEC);
lcd.print("/20");
lcd.print(year, DEC);
But now i want 4 buttons:
S1: Mode
S2: Up
S3: Down
S4: Save
The two modes should be the clock and then some text.
and then the up and down buttons should change the clock’s time.
and Save function to save the clock
and i was wondering how i should add it in the code and on the Arduino
Maybe someone could guide me to a start .
Thanks in Advance :slight_smile:
