Hello
Has anyone worked with the build in RTC on the Controllino Mini? I am having trouble setting up the RTC, the values posted in the serial monitor is just 0.
#include <SPI.h>
#include <Controllino.h> /* Usage of CONTROLLINO library allows you to use CONTROLLINO_xx aliases in your sketch. */
// The setup function runs once when you press reset (CONTROLLINO RST button) or connect power supply
// (USB or external 12V/24V) to the CONTROLLINO.
// initialize serial communication at 9600 bits per second
Controllino_RTC_init(0);
Controllino_SetTimeDate(3,1,10,22,14,10,10); // set initial values to the RTC chip
// the loop function runs over and over again forever
int n;
Serial.print("Day: ");n = Controllino_GetDay(); Serial.println(n);
Serial.print("WeekDay: ");n = Controllino_GetWeekDay(); Serial.println(n);
Serial.print("Month: ");n = Controllino_GetMonth(); Serial.println(n);
Serial.print("Year: ");n = Controllino_GetYear(); Serial.println(n);
Serial.print("Hour: ");n = Controllino_GetHour(); Serial.println(n);
Serial.print("Minute: "); n = Controllino_GetMinute(); Serial.println(n);
Serial.print("Second: ");n = Controllino_GetSecond(); Serial.println(n);
delay(5000);
When running the code and looking in serial monitor it prints a 0 after minut, sec, day etc.
Kind regards Sigurd Havskov
