RTC count 6 seconds per second
Hopefully this is in the right spot on the forum.
I am using the DS1307 real tiny clock module, I see there is a number of posts about it having small inaccuracy ie 20 seconds a week, this however is not my problem.
My problem is that for every 1 second my RTC module seems to count too fast (6 seconds approx).
I am using the setTime sketch example and then the readTest sketch from the DS1307RTC library.
Here is an example output:
setting:
DS1307 configured Time=21:05:42, Date=Feb  5 2020
that works as expected however this is the weird part.
getting time:
Ok, Time = 21:07:26, Date (D/M/Y) = 5/2/2020
Ok, Time = 21:07:32, Date (D/M/Y) = 5/2/2020
Ok, Time = 21:07:38, Date (D/M/Y) = 5/2/2020
and so on.....
This code is updating every second so it is not that.
Until it ends up hours a head in minutes.
Any ideas?
What code would that be ?
For set time:
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
  bool parse=false;
  bool config=false;
  // get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
    parse = true;
    // and configure the RTC with this info
    if (RTC.write(tm)) {
      config = true;
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(200);
  if (parse && config) {
    Serial.print("DS1307 configured Time=");
    Serial.print(__TIME__);
    Serial.print(", Date=");
    Serial.println(__DATE__);
  } else if (parse) {
    Serial.println("DS1307 Communication Error :-{");
    Serial.println("Please check your circuitry");
    Serial.print("Could not parse info from the compiler, Time=\"");
    Serial.print("\", Date=\"");
    Serial.print(__DATE__);
    Serial.println("\"");
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
and getting time sketch:
#include <Wire.h>
  while (!Serial) ; // wait for serial
  delay(200);
  Serial.println("DS1307RTC Read Test");
  Serial.println("-------------------");
  tmElements_t tm;
  if (RTC.read(tm)) {
    Serial.print("Ok, Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    if (RTC.chipPresent()) {
      Serial.println("The DS1307 is stopped.  Please run the SetTime");
      Serial.println("example to initialize the time and begin running.");
      Serial.println("DS1307 read error!  Please check the circuitry.");
    delay(9000);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
What is the output if you turn on the timestamp in the Serial monitor ?
21:21:51.073 -> Ok, Time = 21:24:46, Date (D/M/Y) = 5/2/2020
21:21:52.084 -> Ok, Time = 21:24:51, Date (D/M/Y) = 5/2/2020
21:21:53.070 -> Ok, Time = 21:24:57, Date (D/M/Y) = 5/2/2020
21:21:54.082 -> Ok, Time = 21:25:03, Date (D/M/Y) = 5/2/2020
21:21:55.064 -> Ok, Time = 21:25:09, Date (D/M/Y) = 5/2/2020
21:21:56.079 -> Ok, Time = 21:25:15, Date (D/M/Y) = 5/2/2020
21:21:57.095 -> Ok, Time = 21:25:21, Date (D/M/Y) = 5/2/2020
Totally bizarre. :confused:
It's certainly not in the code as both the setting and reading work properly with my DS1307.
11:05:44.836 -> Ok, Time = 11:05:20, Date (D/M/Y) = 5/2/2020
11:05:45.852 -> Ok, Time = 11:05:21, Date (D/M/Y) = 5/2/2020
11:05:46.871 -> Ok, Time = 11:05:22, Date (D/M/Y) = 5/2/2020
11:05:47.848 -> Ok, Time = 11:05:23, Date (D/M/Y) = 5/2/2020
11:05:48.859 -> Ok, Time = 11:05:24, Date (D/M/Y) = 5/2/2020
11:05:49.868 -> Ok, Time = 11:05:25, Date (D/M/Y) = 5/2/2020
11:05:50.856 -> Ok, Time = 11:05:26, Date (D/M/Y) = 5/2/2020
I can't work out a stuck bit in the seconds register which would cause this defect.
I think there is a defect with the crystal oscillator or some sort of internal divider.
I would treat yourself to a DS3231.
Yeah it's totally strange when for 5 minutes there it remembered what a second was and worked.
How ever it has since forgotten again.
Thanks for the help I will go get a 3231 today :slight_smile:
