Ich baue einen Wecker mit einen 7-Segment Display. Dieser soll die Zeit in Stunden und Minuten anzeigen. Ich verwende ein DS-1302 Modul. Wenn ich den Code laufenlasse gibt er etwas wie
19/80/2091 44:127:1 +
RTC lost confidence in the DateTime!
data read (20) = "⸮
aus. Ist mein DS-1302 kaputt oder habe ich im Programm einen Fehler gemacht?
Hier ist mein Code:
// CONNECTIONS:
// DS1302 CLK/SCLK --> 13
// DS1302 DAT/IO --> 1
// DS1302 RST/CE --> 0
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(1,13,0); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
//7segment display declaration
int pinA = 2;
int pinB = 3;
int pinC = 4;
int pinD = 5;
int pinE = 6;
int pinF = 7;
int pinG = 8;
int D1 = 9;
int D2 = 10;
int D3 = 11;
int D4 = 12;
int digit_1 = 0;
int digit_2 = 8;
int digit_3 = 2;
int digit_4 = 3;
int counter = 0;
#define countof(a) (sizeof(a) / sizeof(a[0]))
const char data[] = "what time is it";
void setup ()
Serial.begin(57600);
//7 segment display setup
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
Serial.println("RTC lost confidence in the DateTime!");
Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
Serial.println("RTC was write protected, enabling writing now");
Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
/* comment out on a second run to see that the info is stored long term */
// Store something in memory on the RTC
uint8_t count = sizeof(data);
uint8_t written = Rtc.SetMemory((const uint8_t*)data, count); // this includes a null terminator for the string
if (written != count)
Serial.print("something didn't match, count = ");
Serial.print(count, DEC);
Serial.print(", written = ");
Serial.print(written, DEC);
/* end of comment out section */
void loop ()
printDateTime(now);
Serial.println(" +");
if (!now.IsValid())
// Common Causes:
// 1) the battery on the device is low or even missing and the power line was disconnected
// read data
uint8_t buff[20];
const uint8_t count = sizeof(buff);
// get our data
uint8_t gotten = Rtc.GetMemory(buff, count);
if (gotten != count)
Serial.print(", gotten = ");
Serial.print(gotten, DEC);
Serial.print("data read (");
Serial.print(gotten);
Serial.print(") = \"");
// print the string, but terminate if we get a null
for (uint8_t ch = 0; ch < gotten && buff[ch]; ch++)
Serial.print((char)buff[ch]);
Serial.println("\"");
//sinc the time
digit_1 = (int)now.Hour()/10;
digit_2 = ((now.Hour())-((int)now.Hour()/10));
digit_3 = (int)now.Minute()/10;
digit_4 = ((now.Minute())-((int)now.Minute()/10));
//display time on th 7 segment display
writeNumber(digit_1, 1);
delay(2);
writeNumber(digit_2, 2);
delay(2);
writeNumber(digit_3, 3);
delay(2);
writeNumber(digit_4, 4);
delay(2);
//debugging the display
Serial.print(digit_1);
Serial.print(digit_2);
Serial.print(":");
Serial.print(digit_3);
Serial.print(digit_4);
Serial.print("\n");
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
//functions to display the time on the 7 segment display
void zero(int digit){
digitSelector(digit);
//0
digitalWrite(pinA, HIGH);
digitalWrite(pinB, HIGH);
digitalWrite(pinC, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
digitalWrite(pinG, LOW);
void nextMinute(){
digit_4++;
if(digit_4 == 10){
digit_4 = 0;
digit_3++;
if(digit_3 == 6){
nextHour();
digit_3 = 0;
void nextHour(){
digit_2++;
if(digit_2 == 10){
digit_2 = 0;
digit_1++;
if(digit_1 == 2 && digit_2 == 4){
digit_1 = 0;
digit_2 = 0;
void writeNumber(int number, int digit){
switch(number){
case 0:
zero(digit);
case 1:
one(digit);
case 2:
two(digit);
case 3:
three(digit);
case 4:
four(digit);
case 5:
five(digit);
case 6:
six(digit);
case 7:
seven(digit);
case 8:
eight(digit);
case 9:
nine(digit);
void one(int digit){
//1
digitalWrite(pinA, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
void two(int digit){
//1
digitalWrite(pinC, LOW);
digitalWrite(pinG, HIGH);
void three(int digit){
//1
void four(int digit){
//1
void five(int digit){
//1
digitalWrite(pinB, LOW);
void six(int digit){
//1
void seven(int digit){
//1
void eight(int digit){
//1
void nine(int digit){
//1
void digitSelector(int digit){
switch (digit) {
case 1:
digitalWrite(D1, LOW);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
digitalWrite(D4, HIGH);
case 2:
digitalWrite(D1, HIGH);
digitalWrite(D2, LOW);
case 3:
digitalWrite(D3, LOW);
case 4:
digitalWrite(D4, LOW);
default:
