RTC DS1307 Help
My RTC will reset to the last time that it was set to after the arduino is disconnected from the computer usb. I have checked the battery with a voltmeter and it reads 3V. Any help would greatly be appreciated!
This is the sketch I use to set the clock...
#include <LCDI2C.h>
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>
LCDI2C lcd = LCDI2C(4,20,0x4C,1);
void setup(void) {
  RTC.stop();
  RTC.set(DS1307_SEC,01);
  RTC.set(DS1307_MIN,32);
  RTC.set(DS1307_HR,17);
  RTC.set(DS1307_DOW,5);
  RTC.set(DS1307_DATE,12);
  RTC.set(DS1307_MTH,1);
  RTC.set(DS1307_YR,12);
  RTC.start();
  lcd.init(); //initialize LCD
int High = 0;
int Low = 10000;
void loop(void){
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract, minute, hour, second, date, month, year, mil_time;
  char buf[12];  //used to convert int to string for displaying on LCD
  //Get time from DS1307
  hour = RTC.get(DS1307_HR,true);
  minute = RTC.get(DS1307_MIN,false);
  second = RTC.get(DS1307_SEC,false);
  date = RTC.get(DS1307_DATE,false);
  month = RTC.get(DS1307_MTH,false);
  year = RTC.get(DS1307_YR,false);
  mil_time = (hour * 100) + minute;  //create military time output
    lcd.setCursor(0,13);
    if((hour < 10 && hour > 0) || (hour > 12 && hour - 12 < 10)){
        lcd.print(" ");
    if(hour > 12){
      lcd.print(hour - 12, DEC);
    if(hour == 0){
    lcd.print(12, DEC);
    if(hour > 0 && hour < 13){
      lcd.print(hour, DEC);
    lcd.print(":");
    if(minute < 10){
      lcd.print("0");
    lcd.print(minute, DEC);
     if(hour < 12 || hour == 0){
     lcd.print("am");
    else{
      lcd.print("pm");
Every time the sketch runs, the code in the setup() function sets the RTC to the hard-coded time. This happens every time it's powered up, and every time the reset button is pressed. Basically that code only needs to run once, not at every reset.
