I tried the other lib guix mentioned. A boat load of compile errors. I looked in the original lib to see where it added the 1900, and I don't have enough experience to notice it. I'm a total noob, so I'll stick my nose back in the books and get some more learning under my belt. I don't expect anyone to do it for me. Thanks again Very Much for the quick replies! Don't worry...I'll be back with more questions, I promise! :')
The Christensen library recommended by guix is rock solid, and is the one I use. If you just replaced the # included library version, you will get compile errors due to the different syntax between the libraries.
gilbertg:
I had the same problem today. I found the DS3231.ccp file had mention of the year 1900. I'm not good with libraries (Noobie), but I replaced 1900 on line 76 with 2000, as well as line 117, then saved the file. No idea what I did, but the date now comes up as 2015.
PS. It has fixed one problem, but may have stuffed up a future one (my guess is turn of the century 2100). But my guess is that no one will be using this code then. We'll probably program thru our home robotic assistance, or maybe in layman's language (via Siri) or maybe even telepathically!
cattledog:
