RTC DS3231 set time end date
How set time rtc with date from system?
I’m using rtc.setTime (__ TIME__) end rtc.setDate(DATE), but it does not work.
// DS3231_Serial_Easy
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// A quick demo of how to use my DS3231-library to
// quickly send time and date information over a serial link
// To use the hardware I2C (TWI) interface of the Arduino you must connect
// the pins as follows:
// Arduino Uno/2009:
// DS3231:  SDA pin   -> Arduino Analog 4 or the dedicated SDA pin
//          SCL pin   -> Arduino Analog 5 or the dedicated SCL pin
// Arduino Leonardo:
// DS3231:  SDA pin   -> Arduino Digital 2 or the dedicated SDA pin
//          SCL pin   -> Arduino Digital 3 or the dedicated SCL pin
// Arduino Mega:
// DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA pin
//          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL pin
// Arduino Due:
// DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA1 (Digital 70) pin
//          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL1 (Digital 71) pin
// The internal pull-up resistors will be activated when using the
// hardware I2C interfaces.
// You can connect the DS3231 to any available pin but if you use any
// other than what is described above the library will fall back to
// a software-based, TWI-like protocol which will require exclusive access
// to the pins used, and you will also have to use appropriate, external
// pull-up resistors on the data and clock signals.
#include <DS3231.h>
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
  // Setup Serial connection
  // Uncomment the next line if you are using an Arduino Leonardo
  //while (!Serial) {}
  // Initialize the rtc object
  rtc.begin();
  // The following lines can be uncommented to set the date and time
  //rtc.setDOW(WEDNESDAY);     // Set Day-of-Week to SUNDAY
  //rtc.setTime(12, 0, 0);     // Set the time to 12:00:00 (24hr format)
  //rtc.setDate(1, 1, 2014);   // Set the date to January 1st, 2014
  rtc.setTime(__TIME__);
  rtc.setDate(__DATE__);
  // Send Day-of-Week
  Serial.print(rtc.getDOWStr());
  Serial.print(" ");
  // Send date
  Serial.print(rtc.getDateStr());
  Serial.print(" -- ");
  // Send time
  Serial.println(rtc.getTimeStr());
  // Wait one second before repeating :)
  delay (1000);
OK. Does it work if you use some of the other options suggested ?
What do you see in the serial monitor ? A data and time which changes every second but from the year 1970 or what ?
What Arduino are you using ?
If I use "rtc.setTime (12, 0, 0) end rtc.setDate (1, 1, 2014)", it works.
I really don't think you can set the date that time will end.
jassbru:
The TIME and DATE preprocessor macros yield string values like this:
11:22:48
Jul 25 2018
Which is different to formats which work for you.
Try finding a DS3231 library which works also with the above format. Stacks of these things have been inflicted upon us, so there is plenty to choose from. Maybe RinkyDinkElectronics, where apparently your example comes from, also have one.
You didn't answer the question about what Arduino you are using.
jassbru:
I'm using rtc.setTime (__ TIME__) end rtc.setDate(DATE), but it does not work.
This does
