RTC help need for programming timers for long strings
some direction into programming strings such as. once i get the ds3231sn to work. I KNOW I BIT OFF MORE THAN I COULD CHEW. BUT WHEN I GET INTO DEEP I USUALLY LEARN BETTER. but since i keep getting errors with old ide and new arduino soft. the only thing i can get to work is the example code which only counts up like a stopwatch.
#include <Wire.h>
Wire.begin();
// clear /EOSC bit
// Sometimes necessary to ensure that the clock
// keeps running on just battery power. Once set,
// it shouldn't need to be reset but it's a good
// idea to make sure.
Wire.beginTransmission(0x68); // address DS3231
Wire.send(0x0E); // select register
Wire.send(0b00011100); // write register bitmap, bit 7 is /EOSC
Wire.endTransmission();
// send request to receive data starting at register 0
Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
Wire.send(0); // start at register 0
Wire.requestFrom(0x68, 3); // request three bytes (seconds, minutes, hours)
while(Wire.available())
int seconds = Wire.receive(); // get seconds
int minutes = Wire.receive(); // get minutes
int hours = Wire.receive(); // get hours
seconds = (((seconds & 0b11110000)>>4)*10 + (seconds & 0b00001111)); // convert BCD to decimal
minutes = (((minutes & 0b11110000)>>4)*10 + (minutes & 0b00001111)); // convert BCD to decimal
hours = (((hours & 0b00110000)>>4)*10 + (hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode)
Serial.print(hours); Serial.print(":"); Serial.print(minutes); Serial.print(":"); Serial.println(seconds);
