Years ago I bought some Arduino stuffs and got sidetracked with other hobbies and shelved everything before really learning anything. Now I've found a little project and have dusted off the ol' starter kit. The project is this one: http://www.instructables.com/id/Arduino-Timer-With-OnOff-Set-Point/
Downloaded the Arduino software and connected everything per the first diagram and loaded the Set_Time_RTC.ino fine and everything worked, but the time was wrong. Googled a bunch and found a thread on this forum where another person found success with a "softrtc" file, which was missing from the library in the Instructables link, but that's sorted now and I can load the softrtc sketch and the correct date is shown via serial monitor. Sweet!
Second step is to get the time displayed on the LCD and it seems something in the Clock_with_RTC_LCD.ino file is redundantly trying to set the RTC, because it causes the correct time to go back to the wrong time. Can someone point me in a direction with where that's happening? Is it the two lines below "//--------Show Actual Time On LCD--------//"?
Here's the Clock_with_RTC_LCD.ino code from the link:
//NJarpa
//Simple clock with RTC 1307
#include <LiquidCrystal.h> //Libraries
#include <RTClib.h>
#include <Wire.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Pines arduino a lcd
//LCD 1602
//2pin to RS, 3pin to EN, D4 to 4pin, D5 to 5pin, D6 to 6pin, D7 to 7pin
//Contrast= 10K potentiometer 1 to Vcc, 2(center)to VO, 3 to GND
//Backlight= K to GND(with 1K resistor), A to Vcc
//Vss to GND , Vdd to +5v
RTC_DS1307 RTC; // define the Real Time Clock object
//RTC 1307
//SDA to analog 4, SCL to analog 5
void setup(){
Wire.begin();
RTC.begin();
lcd.begin(16, 2); // Configura lcd numero columnas y filas
lcd.setCursor(0,0); //Show "TIME" on the LCD
lcd.print("TIME");
void loop(){
DateTime now = RTC.now(); // Clock call
now = RTC.now();
lcd.setCursor(5,0);
if(now.hour() < 10)
lcd.print("0");
lcd.print(now.hour(), DEC); //Print hour
lcd.print(':');
if(now.minute() < 10)
lcd.print("0");
lcd.print(now.minute(), DEC); //Print min
lcd.print(':');
if(now.second() < 10)
lcd.print("0");
lcd.print(now.second(), DEC); //Print sec
