RTC keeps reseting.
I have a few RTC modules with a batteries. All of them have this same issue with my project.
They work fine when connected via USB. But if I disconnect the power then reconnect they reset to Jan 1 2000.
I’ve read several posts about similar problems. But, none seem to apply.
  • The battery is good (tested with volt meter.)
  • The RTC modules work just fine in other projects
Here is my code:
   #include <SFE_MicroOLED.h>  // Include the SFE_MicroOLED library
    #include <SPI.h>
    #include <SD.h>
    #include "Wire.h"
    #include <RTClib.h>
    RTC_DS1307 RTC;
    #define BUTTON_PIN       0 // Button
    #define LONGPRESS_LEN    25  // Min nr of loops for a long press
    #define DELAY            20  // Delay per loop in ms
    enum { EV_NONE=0, EV_SHORTPRESS, EV_LONGPRESS };
    boolean button_was_pressed; // previous state
    int button_pressed_counter; // press running duration
    byte zero = 0x00; //workaround for issue #527
    char* modes[]={"Walk", "Bike", "Subway", "Train", "Bus", "X-Bus", "Waiting", "Other"};
    byte mode=0;
    int modeRead;
    // Chip Select for SD
    #define chipSelect 10
    //MicroOLED oled(PIN_RESET, PIN_DC, PIN_CS);
    MicroOLED oled(9, 8, 5); // SPI declaration
      pinMode(BUTTON_PIN, INPUT);
      digitalWrite(BUTTON_PIN, HIGH); // pull-up
      button_was_pressed = false;
      button_pressed_counter = 0;
      SD.begin(chipSelect);
      Wire.begin();
      RTC.begin();
      //RTC.adjust(DateTime(__DATE__, __TIME__));
      oled.begin();    // Initialize the OLED
      oled.clear(PAGE);     // Clear the screen
      oled.setFontType(1);  // Set font to type 0
      oled.setCursor(0, 0); // Set cursor to top-left
      oled.println(F("co'mute"));
      oled.display();  // Display what's in the buffer
    int handle_button()
      int event;
      int button_now_pressed = !digitalRead(BUTTON_PIN); // pin low -> pressed
      if (!button_now_pressed && button_was_pressed) {
        if (button_pressed_counter < LONGPRESS_LEN)
          event = EV_SHORTPRESS;
          event = EV_LONGPRESS;
        event = EV_NONE;
      if (button_now_pressed)
        ++button_pressed_counter;
      button_was_pressed = button_now_pressed;
      return event;
    void printDate () {
      oled.setFontType(0);  // Set font to type 0
      DateTime now = RTC.now();
        oled.print(now.year(), DEC);
        oled.print('/');
        oled.print(now.month(), DEC);
        oled.print('/');
        oled.print(now.day(), DEC);
        oled.print(' ');
        oled.print(now.hour(), DEC);
        oled.print(':');
          if (now.minute()<10) {
          oled.print("0");
        oled.print(now.minute(), DEC);
        oled.print(':');
        if (now.second()<10) {
          oled.print("0");
        oled.print(now.second(), DEC);
        oled.println();
      oled.println(modes[mode]);
     oled.display();   // Display what's in the buffer (splashscreen)
    void writeFile() {
    File dataFile = SD.open("datalog.txt", FILE_WRITE);
    // If the file is available, write to it:
    if (dataFile) {
    //print the date EG   3/1/11 23:59:59
        dataFile.print(now.year(), DEC);
        dataFile.print('/');
        dataFile.print(now.month(), DEC);
        dataFile.print(now.day(), DEC);
        printDate ();
        oled.print("*SAVED*");
        oled.display();
     delay(3000);
    void loop()          // run over and over again
      // handle button
      boolean event = handle_button();
      // do other things
      switch (event) {
        case EV_NONE:
          oled.print(".");
        case EV_SHORTPRESS:
          oled.print("S");
          //modeRead = analogRead(0);    // read the value from the sensor
          writeFile();
        case EV_LONGPRESS:
          oled.print("L");
      static int counter = 0;
      if ((++counter & 0X016) == 0) {
     printDate ();
      modeRead = analogRead(A0);    // read the value from the sensor
      delay(DELAY);
      int c=1020/(sizeof(modes)/sizeof(modes[0]));
      for (int i = 0; i < c; i++) {
      if (i*c < modeRead && (i+1)*c < modeRead) {
        mode = i;
In this diagram the “pressure sensor” is really a OLED that operates via MOSI and MISO.
Does your LiPo battery or that charger/booster output 5 volts or 3.7 volts ?
Do you have some other power supply to test without this battery, and without USB power ?
You have enabled the RTC? I presume RTClib::adjust() does this?
I am confused why the SPI parts aren't using the SPI pins (not that that's relevant)
