Hello,
For some reason there is a problem in my void loop section.
I try to display the day, month, clock, date, temp and humidity.
that all worked fine in the past but now wen i wanna change the time to the new
time i get allot of characters flickering over the lcd.
And every second the time is barley visible.
The things that are connected are:
A 20x4 blue LCD on SCL, SDA
A DHT Sensor on pin 2
A RTC DS3231 on SCL, SDA
Can someone help me please.
This is my code:
#include <Wire.h>
#include <DS3231.h>
#include "DHT.h"
DS3231 rtc(SDA, SCL); //SDA, SCL
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
byte newCharHorizontal[] = {
B00000,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharVerticalLeft[] = {
B01000,
B01000,
B01000,
B01000,
B01000,
B01000,
B01000,
B01000
byte newCharVerticalRight[] = {
B00010,
B00010,
B00010,
B00010,
B00010,
B00010,
B00010,
B00010
byte newCharLeftCorner[] = {
B01000,
B11000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharRightCorner[] = {
B00010,
B00011,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharLogoTop[] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B00000
byte newCharLogoBottom[] = {
B00000,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharLogoBottomLeftCorner[] = {
B00010,
B00011,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharLogoBottomRightCorner[] = {
B01000,
B11000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte newCharLogoTopLeftCorner[] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00011,
B00010
byte newCharLogoTopRightCorner[] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11000,
B01000
byte newCharLogoVerticalLeft[] = {
B01000,
B01000,
B01000,
B01000,
B01000,
B01000,
B01000,
B01000
byte newCharLogoVerticalRight[] = {
B00010,
B00010,
B00010,
B00010,
B00010,
B00010,
B00010,
B00010
byte newCharDegreesCelcius[] = {
B01000,
B10100,
B01000,
B00011,
B00100,
B00100,
B00011,
B00000
byte newCharBlock[] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
dht.begin();
rtc.begin();
//rtc.setTime(18, 53, 00);
//rtc.setDate(16, 02, 2020);
lcd.begin(20,4);
lcd.createChar(5, newCharLogoTop);
lcd.createChar(6, newCharLogoBottom);
lcd.createChar(7, newCharLogoBottomLeftCorner);
lcd.createChar(8, newCharLogoBottomRightCorner);
lcd.createChar(9, newCharLogoTopLeftCorner);
lcd.createChar(10, newCharLogoTopRightCorner);
lcd.createChar(11, newCharLogoVerticalLeft);
lcd.createChar(12, newCharLogoVerticalRight);
// Top Lines
lcd.setCursor(3,0);
lcd.write(byte(5));
lcd.setCursor(4,0);
lcd.write(byte(5));
lcd.setCursor(5,0);
lcd.write(byte(5));
lcd.setCursor(6,0);
lcd.write(byte(5));
lcd.setCursor(7,0);
lcd.write(byte(5));
lcd.setCursor(8,0);
lcd.write(byte(5));
lcd.setCursor(9,0);
lcd.write(byte(5));
lcd.setCursor(10,0);
lcd.write(byte(5));
lcd.setCursor(11,0);
lcd.write(byte(5));
lcd.setCursor(12,0);
lcd.write(byte(5));
lcd.setCursor(13,0);
lcd.write(byte(5));
lcd.setCursor(14,0);
lcd.write(byte(5));
lcd.setCursor(15,0);
lcd.write(byte(5));
lcd.setCursor(16,0);
lcd.write(byte(5));
// Bottom Lines
lcd.setCursor(3,3);
lcd.write(byte(6));
lcd.setCursor(4,3);
lcd.write(byte(6));
lcd.setCursor(5,3);
lcd.write(byte(6));
lcd.setCursor(6,3);
lcd.write(byte(6));
lcd.setCursor(7,3);
lcd.write(byte(6));
lcd.setCursor(8,3);
lcd.write(byte(6));
lcd.setCursor(9,3);
lcd.write(byte(6));
lcd.setCursor(10,3);
lcd.write(byte(6));
lcd.setCursor(11,3);
lcd.write(byte(6));
lcd.setCursor(12,3);
lcd.write(byte(6));
lcd.setCursor(13,3);
lcd.write(byte(6));
lcd.setCursor(14,3);
lcd.write(byte(6));
lcd.setCursor(15,3);
lcd.write(byte(6));
lcd.setCursor(16,3);
lcd.write(byte(6));
// Corners
lcd.setCursor(2,0);
lcd.write(byte(9));
lcd.setCursor(2,3);
lcd.write(byte(7));
lcd.setCursor(17,0);
lcd.write(byte(10));
lcd.setCursor(17,3);
lcd.write(byte(8));
// Vertical Lines
lcd.setCursor(2,1);
lcd.write(byte(12));
lcd.setCursor(2,2);
lcd.setCursor(17,1);
lcd.write(byte(11));
lcd.setCursor(17,2);
lcd.setCursor(5,1);
lcd.print("DV Servers");
lcd.setCursor(3,2);
lcd.print("Danny Verhaert");
delay(5000);
lcd.clear();
lcd.createChar(0, newCharHorizontal);
lcd.createChar(1, newCharVerticalLeft);
lcd.createChar(2, newCharLeftCorner);
lcd.createChar(3, newCharRightCorner);
lcd.createChar(4, newCharVerticalRight);
lcd.createChar(13, newCharDegreesCelcius);
lcd.createChar(14, newCharBlock);
// Left Corner
lcd.setCursor(3,0);
lcd.write(byte(1));
lcd.setCursor(0,1);
lcd.write(byte(0));
lcd.setCursor(1,1);
lcd.write(byte(0));
lcd.setCursor(2,1);
lcd.write(byte(0));
lcd.setCursor(3,1);
lcd.write(byte(2));
// Right Corner
lcd.write(byte(4));
lcd.setCursor(16,1);
lcd.write(byte(3));
lcd.setCursor(18,1);
lcd.write(byte(0));
lcd.setCursor(19,1);
lcd.write(byte(0));
lcd.write(byte(0));
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
lcd.setCursor(0,3);
lcd.println(F("N/A"));
return;
float hic = dht.computeHeatIndex(t, h, false);
lcd.print(h);
lcd.print("%");
lcd.setCursor(0,0);
lcd.print(rtc.getDOWStr(FORMAT_SHORT ));
lcd.print(rtc.getMonthStr(FORMAT_SHORT));
lcd.setCursor(6,1);
lcd.print(rtc.getDateStr(FORMAT_SHORT, FORMAT_LITTLEENDIAN, '/'));
lcd.setCursor(6,2);
lcd.print(rtc.getTimeStr());
lcd.setCursor(0,3);
lcd.print(t);
//lcd.print(rtc.getTemp() - 2);
lcd.write(byte(13)); //
Thank you in advance.
Danny
