I have a problem. So I needed a library for DS3231. So I went into the Arduino’s “manage libraries” and found a library named DS3231. But, when I click on it to add it, it comes up as <Wire.h>, which isnt what I wanted. It is supposed to come up as:
#define <DS3231.h> but it isn’t.
I wanted to use the example code that most tutorials are using. There isn’t the right example code either. So, I relized it mustve been the wrong library.
I went to Rink-dink electronics(the library the tutorials say to use) and downloaded the DS3231 library. I went to downlad it as a library and it said, “Library of the same name already exists”. How do I get the library I want. Can I uninstall the first library??? If so, how do I do that?
3rd party libraries are installed in the libraries directory in the Arduino sketch directory; under windows C:\Users\yourUsername\Documents\Arduino\libraries.
You can simply delete them there.
I'm still not exactly sure what youre trying to say. I have a mac... does that make a difference? Sorry, I'm new.
pearl2007:
That’s a common mistake library authors make. They don’t bother to read the documentation and so they mess up the library metadata. But it’s really not a problem. Just type the #include directive yourself instead of using the Arduino IDE’s Sketch > Include Library feature. If you don’t know the file name, check the examples that come with the library. They are found at File > Examples > {library name}.
I submitted a pull request to fix that error in the library 6 months ago, but it hasn’t been merged yet:
https://github.com/NorthernWidget/DS3231/pull/15
pearl2007:
Yes.
pearl2007:
- (In the Arduino IDE) File > Preferences
- Note the folder location shown in the “Sketchbook location” preference. This is your sketchbook.
- Delete the folder {sketchbook folder}/libraries/DS3231
After doing that, you’ll be able to install the other DS3231 library.
pert:
That's a common mistake library authors make. They don't bother to read the documentation and so they mess up the library metadata. But it's really not a problem. Just type the #include directive yourself instead of using the Arduino IDE's Sketch > Include Library feature. If you don't know the file name, check the examples that come with the library. They are found at File > Examples > {library name}.I submitted a pull request to fix that error in the library 6 months ago, but it hasn't been merged yet:
Correct includes value in library.properties by per1234 · Pull Request #15 · NorthernWidget/DS3231 · GitHub
Yes.
- Note the folder location shown in the "Sketchbook location" preference. This is your sketchbook.
After doing that, you'll be able to install the other DS3231 library.
Oh my goodness thank you!!! That should work. I was trying to find out how to do this but I couldnt understand what they were sying. This was really conprehensive. Thank you!
You're welcome. I'm glad if I was able to be of assistance.
Per
