Hello
I am desperate since I cannot compile the code below since days. Before it worked. I guess it came since I updated libraries.
I found, that this error only appears when I use the DCF77 and RTC library together. I think there is some conflict. You can find the code attached. The error message you can read below:
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp: In member function 'void DS1307::setEpoch(time_t)':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:424:12: error: aggregate 'DS1307::setEpoch(time_t)::tm epoch_tm' has incomplete type and cannot be defined
struct tm epoch_tm, * ptr_epoch_tm;
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:427:17: error: 'gmtime' was not declared in this scope
ptr_epoch_tm = gmtime(&rawtime);
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp: In member function 'void PCF8563::setEpoch(time_t)':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:313:15: error: aggregate 'PCF8563::setEpoch(time_t)::tm epoch_tm' has incomplete type and cannot be defined
struct tm epoch_tm , *ptr_epoch_tm;
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:317:20: error: 'gmtime' was not declared in this scope
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp: In member function 'void DS3231::setEpoch(time_t, time_t, int16_t)':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:526:12: error: aggregate 'DS3231::setEpoch(time_t, time_t, int16_t)::tm epoch_tm' has incomplete type and cannot be defined
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:531:17: error: 'gmtime' was not declared in this scope
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:531:17: note: suggested alternative: 'setTime'
setTime
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp: In member function 'time_t DS3231::getEpoch()':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:551:12: error: aggregate 'DS3231::getEpoch()::tm epoch_tm' has incomplete type and cannot be defined
struct tm epoch_tm;
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:561:10: error: 'mktime' was not declared in this scope
epoch = mktime(&epoch_tm);
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:427:17: note: suggested alternative: 'setTime'
setTime
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:317:20: note: suggested alternative: 'setTime'
setTime
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp: In member function 'time_t DS1307::getEpoch()':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:445:12: error: aggregate 'DS1307::getEpoch()::tm epoch_tm' has incomplete type and cannot be defined
struct tm epoch_tm;
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:453:10: error: 'mktime' was not declared in this scope
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp: In member function 'time_t PCF8563::getEpoch()':
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:337:15: error: aggregate 'PCF8563::getEpoch()::tm epoch_tm' has incomplete type and cannot be defined
struct tm epoch_tm;
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:347:13: error: 'mktime' was not declared in this scope
epoch = mktime (&epoch_tm);
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS3231.cpp:561:10: note: suggested alternative: 'setTime'
setTime
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\PCF8563.cpp:347:13: note: suggested alternative: 'setTime'
setTime
C:\Users\urshe\Documents\Arduino\libraries\RTC\src\DS1307.cpp:453:10: note: suggested alternative: 'setTime'
setTime
exit status 1
Error compiling for board Arduino Nano.
Thank you for any hint to solve it.
BirdWatch.ino (13.9 KB)
