I can t find a library for the RTC M41T00 it has the same adresse as the DS1307 can i make some changes in this library and use it for the M41T00? Does anyone has an experience working with M41T00?
helppp pleaseeeee
The same I2C address doesn't mean it uses the same register setup. Fortunately the register map is similar enough to let you probably use the simple routines of the DS1307 library with your chip.
Your chip doesn't support the {s,g}etCalibration() method but the rest of the library should work with your chip too.
