I have problem with my rtc project that I'm doing for school. I'm not sure what is wrong but my rtc gets pushed back gradually and in about 23 hours its back about 7 minutes. I am using this library
and the LiquidCrystal library that comes with the Arduino IDE. attached you will find the code for my project. Any help is appreciated
A ds3231 shouldn't drift that much per day. They do have an "aging offset" register that allows you to increase/decrease the oscillator frequency. You should see what it currently is at and increase it (speed of the oscillator). datasheet
blh64:
How do i access this "aging offset" register? I'm very new to this
JekieBoi:
You look at the datasheet which defines the address of all the internal registers and read the proper one. If you look at the library you are using (inside the .h file) the author may have already written a function to do this. It is really no different than reading other internal registers which happen to hold the date/time.
blh64:
Seven minutes error in 23 hours? I have a feeling that this is too big a job for any aging offset register...
