Hey there, I'm using an Arduino Nano 2040 Connect and was checking out @Klaus_K code in this thread: RTC on Arduino Nano 33 BLE?. It does work up to the point where the time should update, i.e. it's always 11:59:59PM. Do you have an idea how to solve this? I also can read and write using EFR Connect but when reading after writing some date, the date will again be 1.1.1970.
If you need help for the Arduino Nano 33 BLE please check out his answer in this thread: RTC on Arduino Nano 33 BLE?
@Klaus_K code example
This example creates a BLE peripheral with a Current Time Service.
The circuit:
- Arduino Nano 33 BLE or BLE Sense
You can use a generic BLE central app, like LightBlue (iOS and Android) or
nRF Connect (Android), to interact with the services and characteristics
created in this sketch.
The EFR Connect App from Silicon Labs (iOS) can decode and write the currentTimeService.
This example code is in the public domain.
#include <ArduinoBLE.h>
#include <mbed.h>
// BLE UUIDs
#define BLE_UUID_CURRENT_TIME_SERVICE "1805"
#define BLE_UUID_DATE_TIME "2A08"
// BLE Date Time
typedef struct __attribute__( ( packed ) )
uint16_t year;
uint8_t month;
uint8_t day;
uint8_t hours;
uint8_t minutes;
uint8_t seconds;
} date_time_t;
union date_time_data
date_time_t dateTime;
uint8_t bytes[ sizeof( date_time_t ) ];
union date_time_data dateTimeData;
// BLE
#define BLE_DEVICE_NAME "Arduino Nano 33 BLE"
#define BLE_LOCAL_NAME "Arduino Nano 33 BLE"
BLEService currentTimeService( BLE_UUID_CURRENT_TIME_SERVICE );
BLECharacteristic dateTimeCharacteristic( BLE_UUID_DATE_TIME, BLERead | BLEWrite | BLENotify, sizeof dateTimeData.bytes );
// I/O and App
#define BLE_LED_PIN LED_BUILTIN
bool timeUpdated = false;
Serial.begin( 9600 );
// while ( !Serial );
pinMode( BLE_LED_PIN, OUTPUT );
setupTime();
if ( !setupBleMode() )
Serial.println( F( "Failed to initialize BLE!" ) );
while ( 1 );
Serial.println( F( "BLE initialized. Waiting for clients to connect." ) );
timeTask();
bleTask();
bool setupBleMode()
if ( !BLE.begin() )
return false;
// set advertised local name and service UUID
BLE.setDeviceName( BLE_DEVICE_NAME );
BLE.setLocalName( BLE_LOCAL_NAME );
BLE.setAdvertisedService( currentTimeService );
// add characteristics
currentTimeService.addCharacteristic( dateTimeCharacteristic );
// add service
BLE.addService( currentTimeService );
// set the initial value for the characeristics
dateTimeCharacteristic.writeValue( dateTimeData.bytes, sizeof dateTimeData.bytes );
// set BLE event handlers
BLE.setEventHandler( BLEConnected, blePeripheralConnectHandler );
BLE.setEventHandler( BLEDisconnected, blePeripheralDisconnectHandler );
// set service and characteristic specific event handlers
dateTimeCharacteristic.setEventHandler( BLEWritten, bleCharacteristicWrittenHandler );
// start advertising
BLE.advertise();
return true;
void bleTask()
#define BLE_UPDATE_INTERVAL 10
static uint32_t previousMillis = 0;
uint32_t currentMillis = millis();
if ( currentMillis - previousMillis >= BLE_UPDATE_INTERVAL )
BLE.poll();
if ( timeUpdated )
void bleCharacteristicWrittenHandler( BLEDevice central, BLECharacteristic bleCharacteristic )
if ( bleCharacteristic.uuid() == ( const char* ) BLE_UUID_DATE_TIME )
dateTimeCharacteristic.readValue( dateTimeData.bytes, sizeof dateTimeData.bytes );
setTime( dateTimeData.dateTime );
void blePeripheralConnectHandler( BLEDevice central )
digitalWrite( BLE_LED_PIN, HIGH );
Serial.print( F( "Connected to central: " ) );
Serial.println( central.address() );
void blePeripheralDisconnectHandler( BLEDevice central )
digitalWrite( BLE_LED_PIN, LOW );
Serial.print( F( "Disconnected from central: " ) );
void timeTask()
#define TIME_UPDATE_INTERVAL 1000
if ( currentMillis - previousMillis < TIME_UPDATE_INTERVAL )
return;
time_t currentTime = time( NULL );
struct tm * now = localtime( ¤tTime );
dateTimeData.dateTime.year = now->tm_year + 1900;
dateTimeData.dateTime.month = now->tm_mon + 1;
dateTimeData.dateTime.day = now->tm_mday;
dateTimeData.dateTime.hours = now->tm_hour;
dateTimeData.dateTime.minutes = now->tm_min;
dateTimeData.dateTime.seconds = now->tm_sec;
timeUpdated = true;
void setupTime( void )
date_time_t dateTime = { 2021, 5, 27, 0, 0 , 0 };
setTime( dateTime );
void setTime( date_time_t time )
struct tm setTime;
setTime.tm_mon = time.month - 1; // month are from (0 - 11)
setTime.tm_year = time.year - 1900; // years since 1900
setTime.tm_mday = time.day; // day of month (0 - 31)
setTime.tm_hour = time.hours; // hour (0 - 23)
setTime.tm_min = time.minutes; // minutes (0 - 59)
setTime.tm_sec = time.seconds; // seconds (0 - 59)
set_time( mktime( &setTime ) );
