RTC on M4 accessible
Since I didn't find it in the GIGA R1 dual core guide, the RTC can be accessed from the M4. Here is an example code that I uploaded to both cores (make sure to select some memory for the M4 as well):
#include "mbed.h"
#include <mbed_mktime.h>
#include "RPC.h"
constexpr unsigned long printInterval { 1000 };
unsigned long printNow {};
    RPC.begin();
    if (RPC.cpu_id() == CM7_CPUID) {
      Serial.begin(19200);
      while (!Serial) {
        ; // Wait for Serial (USB) connection
      Serial.println("M7: Serial connection initiated");
      //RTCset()  //Uncomment if you need to set the RTC for the first time.
      RPC.println("M4: Reading the RTC.");
      if (RPC.available()) {
        char incomingByte = RPC.read();  // Read byte from RPC
        Serial.write(incomingByte);  // Forward the byte to Serial (USB)
        if (millis() > printNow) {
        RPC.print("M4 System Clock: ");
        RPC.println(getLocaltime());
        printNow = millis() + printInterval;
String getLocaltime()
    char buffer[32];
    tm t;
    _rtc_localtime(time(NULL), &t, RTC_4_YEAR_LEAP_YEAR_SUPPORT);
    strftime(buffer, 32, "%Y-%m-%d %k:%M:%S", &t);
    return String(buffer);
void RTCset()  // Set cpu RTC
  tm t;
            t.tm_sec = (0);       // 0-59
            t.tm_min = (58);        // 0-59
            t.tm_hour = (11);         // 0-23
            t.tm_mday = (1);   // 1-31
            t.tm_mon = (9);       // 0-11  "0" = Jan, -1
            t.tm_year = ((24)+100);   // year since 1900,  current year + 100 + 1900 = correct year
            set_time(mktime(&t));       // set RTC clock
Thanks for posting this. I am at present trying to decide how to break up tasks between the M7 and M4 in my project. Sending the RTC off to the M4 is certainly a consideration.
