RTC program help with LED
What version of the IDE are you running?
Where did you get the RTC library?
Edit:
I found the library and updated the code offered in post #19
now my code says 'RTC_DS3231' does not display a type
I believe this is the library I am using with the code in post #19.
okay so i figured it out what i did wrong. WHEW! im working on this project so i can eventually work with a motor driver and linear actuator. I need to modify this program to have 8 cases instead of 3. can you help me add the others? this really has been a tremendous help!
