RTC Relay control
Hi all
Could someone please help me with the code for a setup I would like to do:
A relay that is triggered at a specific time(RTC) but I would still like to have a digital switch to turn it on when I choose.
I've found a link for just the RTC control but not to have a switch with it.
any help would be appreciated. Thanks
just look at any example reading a button press. add in your code that if the button is pressed and the relay active, then turn off the relay
J-M-L: just look at any example reading a button press. add in your code that if the button is pressed and the relay active, then turn off the relay
Thank, that is so easy lol.
post the code within code tags so that it looks good like this
// good looking code
bad looking code
void setup() { // put your setup code here, to run once:
void loop() { // put your main code here, to run repeatedly:
J-M-L: post the code within code tags so that it looks good like this
**bad looking code**
Will do, I still a bit new, have played around much.
But will try to keep the code looking nice. Thanks
