coltex
March 26, 2024, 4:18pm
1
Hello.
I have a strange phenomenon concerning I2C bus modules.
Modules: RTC SD2405 I2C and LCD1602 RGB
I'm trying to display text on an this LCD. It works fine until I use the RTC module. Then it starts endlessly displaying the last letter of the text.
(Everything from one company DFRobot , i belive it should work together)
The simplified code looks like this:
#include "GravityRtc.h"
#include "Wire.h"
#include "DFRobot_RGBLCD1602.h"
GravityRtc rtc; // Init RTC
DFRobot_RGBLCD1602 lcd(/*RGBAddr*/0x2D ,/*lcdCols*/16,/*lcdRows*/2); //16 characters and 2 lines of show
rtc.setup();
lcd.init();
lcd.setRGB(111,254,244);
lcd.print("Texting");
rtc.read();
Serial.print(" Hour = "); // godzina
Serial.print(rtc.hour);
Serial.print(" Minute = "); // minuta
Serial.print(rtc.minute);
Serial.print(" Second = "); // sekunda
Serial.println(rtc.second);
Connections as in the picture:
Thank you for any help.
There's no printing to the LCD in this code except for "Texting" in Setup.
Koepel
March 26, 2024, 7:01pm
3
DFRobot LCD with RGB Backlight: https://www.dfrobot.com/product-1609.html
That is confusing, the display has a RGB_address and a I2C_address.
The RGB_address depends on the module:
Moudule | Version| RGBAddr|
LCD1602 Module | V1.0 | 0x60 |
LCD1602 Module | V1.1 | 0x6B |
LCD1602 RGB Module | V1.0 | 0x60 |
LCD1602 RGB Module | V2.0 | 0x2D |
The I2C_address seems to be fixed to 0x3E : https://github.com/DFRobot/DFRobot_RGBLCD1602/blob/master/DFRobot_RGBLCD1602.h#L24
The DFRobot RTC module: https://wiki.dfrobot.com/Gravity__I2C_SD2405_RTC_Module_SKU__DFR0469
It's I2C address seems to be fixed to 0x32 : https://github.com/DFRobot/Gravity-I2C-SD2405-RTC-Module/blob/master/GravityRtc/GravityRtc.h#L25
Things to do:
Please split the wires. The flat ribbon cable has 4 wires to each other. Split those wires please.
Run a I2C Scanner sketch with nothing connected, then with only the RTC connected, then with only the display connected, then with both.
coltex
March 26, 2024, 9:26pm
4
Thank you for your willingness to help.
When I scan only RTC :
I2C device found at address 0x32
When I scan only LCD :
I2C device found at address 0x2D
I2C device found at address 0x3E
When I scan two I got 3 adresses.
So, LCD use 2 adresses ? maybe.
But , Now I see one more thing.
I I disconect modul of RTC , its the sam.
It looks like there is indeed a software problem.
it endlessly displaying the last letter of the text too.
Maybe problem in library from DTRobot ?
If I comment this line :
//rtc.read ();
LCD start work properly. (RTC of course not.)
Hi, @coltex
Welcome to the forum.
Have you tested the RTC on its own, with its own code?
Thanks.. Tom..
coltex
March 26, 2024, 9:52pm
6
Hello,
I use libraries from DFRobot - vendor of LCD and RTC.
I just try with other library from DFRobot - "DFRobot_LCD.h" but the same efect.
Problem is in software, I can disconnect RTC - its the same.
Characters on display LCD appear in every cycle of this line :
rtc.read();
I have no idea why.
Besides this RTC work properly.
The RTC library interferes with the operation of the LCD module.
system
Closed
September 22, 2024, 9:52pm
7
